Jordan.M Posted May 4, 2014 Report Share Posted May 4, 2014 Has anyone actually used these markers? I usually buy the standard sharpies at HD for $.68 a piece but these new Milwaukee ones are advertised to work a little bit better for construction purposes. I use them daily for marking anchor points on walls, marking conduit for bends, and marking stuff to be cut. http://www.homedepot.com/p/Milwaukee-Inkzall-Black-Fine-Point-Bulk-Marker-48-22-3100/204813511 Quote Link to comment Share on other sites More sharing options...
frankiegarcia19 Posted May 4, 2014 Report Share Posted May 4, 2014 Just got one...yet to use it...hopefully it works on oily services.... Quote Link to comment Share on other sites More sharing options...
TylerDama Posted May 4, 2014 Report Share Posted May 4, 2014 It is nice..Javier has a review on it on his YouTube page "tool crazy".personally I find it is very similar to the sharpie pro other then the fact that the Milwaukee has a hard hat clip. Quote Link to comment Share on other sites More sharing options...
NicholasShetley Posted May 4, 2014 Report Share Posted May 4, 2014 I like it because it will stand out more since it is red instead of gray. Quote Link to comment Share on other sites More sharing options...
RedSionnach Posted May 4, 2014 Report Share Posted May 4, 2014 Here's Javiers review. 1 Quote Link to comment Share on other sites More sharing options...
Javier Posted May 5, 2014 Report Share Posted May 5, 2014 Thanks Tyler and RedSionach.The inkzall aced all the tests on the laminate- dusty wet and oily surface. The sharpie pro did the best on a ceramic tile and wet tile cutting. Although the inkzall isn't more durable than a normal sharpie. The sharpie pro is the king in the durability department. For some reason the sharpie pro did the worst out of the wet and oily test in the laminate. On plastic the only one that had their ink not smear immediately was the sharpie pro. Quote Link to comment Share on other sites More sharing options...
TylerDama Posted May 6, 2014 Report Share Posted May 6, 2014 Thanks Tyler and RedSionach.The inkzall aced all the tests on the laminate- dusty wet and oily surface. The sharpie pro did the best on a ceramic tile and wet tile cutting. Although the inkzall isn't more durable than a normal sharpie. The sharpie pro is the king in the durability department. For some reason the sharpie pro did the worst out of the wet and oily test in the laminate. On plastic the only one that had their ink not smear immediately was the sharpie pro.I have been using the sharpie pro since your review (very well done by the way) and very satisfied, the yellow rubber molding really makes a difference when it comes to grip.... but the clip breaks very easy. After a few weeks I think I will try the inkzall in hopes it holds up better. 1 Quote Link to comment Share on other sites More sharing options...
Javier Posted May 15, 2014 Report Share Posted May 15, 2014 Tyler, did your sharpie pro have the same issue as mine where the white sleeve inside the cap came loose? Just curious, other than that the sharpie pro is a very good marker Quote Link to comment Share on other sites More sharing options...
mustang347 Posted May 15, 2014 Report Share Posted May 15, 2014 Javier, I've had that exact same problem quite a few times with the sharpie pro. Pretty annoying when you only have one hand free and that happens. Quote Link to comment Share on other sites More sharing options...
TylerDama Posted May 16, 2014 Report Share Posted May 16, 2014 Yes Javier, that had been a problem with the pro I've experienced. Quote Link to comment Share on other sites More sharing options...
