Dan - TIA Posted December 21, 2010 Report Share Posted December 21, 2010 There is something cool about old tools. Post your old tool pictures or stories here. Link to comment Share on other sites More sharing options...
dewaltking Posted December 21, 2010 Report Share Posted December 21, 2010 They don't make them like they use to Link to comment Share on other sites More sharing options...
mariog207 Posted August 4, 2011 Report Share Posted August 4, 2011 (edited) craftsman commercial grinder.pic of grinder I found online model # 335.25841 My craftsman commercial hand grinder tag. clear to the eye, just cheap cell camera, can't find a manufacturer date. works great, had to grind off stripped lug nuts w/tire on car, grey plastic sears case it came in had a bunch of different grit/size/shape grinding bits in it, very kool. Edited August 4, 2011 by mariog207 Link to comment Share on other sites More sharing options...
Eric - TIA Posted August 6, 2011 Report Share Posted August 6, 2011 Thats very cool. I am not sure the date, but wondering about the plastic case. It looks old, but the plastic case makes me wonder how old. I am not sure when they went from the metal case to plastic cases. Link to comment Share on other sites More sharing options...
mariog207 Posted August 8, 2011 Report Share Posted August 8, 2011 (edited) Thats very cool. I am not sure the date, but wondering about the plastic case. It looks old, but the plastic case makes me wonder how old. I am not sure when they went from the metal case to plastic cases. Here's the front of caseTop: Sears Label on top left cornerAnd here's what was inside, even adapter for smaller bits, sure all those were added by previous owner.On tag says 24000 R.P.M40 deg c rise (idk)max 1 1/2 inch dia wheel w/1 inch shank mounted points(?).And at bottom it says:Sears, Roebuck & co.Simpsons-Sears LTDclick on link you will see it pop up for a second then message about item ended, only thing I found so far. still searching.http://cgi.ebay.com/VINTAGE-CRAFTSMAN-BALL-BEARING-INDUSTRIAL-HAND-GRINDER-/250821019902?pt=LH_DefaultDomain_0 Edited August 8, 2011 by mariog207 Link to comment Share on other sites More sharing options...
mariog207 Posted August 10, 2011 Report Share Posted August 10, 2011 Here's the front of caseTop: Sears Label on top left cornerAnd here's what was inside, even adapter for smaller bits, sure all those were added by previous owner.On tag says 24000 R.P.M40 deg c rise (idk)max 1 1/2 inch dia wheel w/1 inch shank mounted points(?).And at bottom it says:Sears, Roebuck & co.Simpsons-Sears LTDclick on link you will see it pop up for a second then message about item ended, only thing I found so far. still searching.http://cgi.ebay.com/VINTAGE-CRAFTSMAN-BALL-BEARING-INDUSTRIAL-HAND-GRINDER-/250821019902?pt=LH_DefaultDomain_0Found out Simpson-Sears is a Canadian based Sears.Grinder must not be worth much, and not very popular in U.S.Canadian based sear's, maybe I should Google some Canadian tool forums and see what they come up with. Link to comment Share on other sites More sharing options...
Circusmonkey Posted August 10, 2011 Report Share Posted August 10, 2011 WOW that is awesome. its like one of the first rotary tools I have seen! Great find Link to comment Share on other sites More sharing options...
mariog207 Posted August 12, 2011 Report Share Posted August 12, 2011 Thanks I was sent this 72-73 Sears catalog with grinder on page 18.http://www.roseantiquetools.com/sitebuildercontent/sitebuilderfiles/197273craftsman15.5mb.pdfI also found these vise type things, possibly pipe benders, not sure, prev renter was a welder.Thanks again Link to comment Share on other sites More sharing options...
Eric - TIA Posted August 13, 2011 Report Share Posted August 13, 2011 The catalog is cool. There is just something about old tools that is just plain awesome. I am not sure about the items above, I am not a welder. Tried it once and all most burnt down the garage. Link to comment Share on other sites More sharing options...
