Bremon Posted July 22, 2016 Report Posted July 22, 2016 Well crew, what are your thoughts on these? Do you use one? What are some anecdotes about the jams they've gotten you out of. What make/model do you use? Note, I'm not talking about hole hawgs or super hawgs here, though I'd like to hear stories about them as well. I know they kick serious amounts of ass. What I'm talking about is the range of models that seems to be saturated by right angle drills that have 100-200ish inch pounds of torque, 3/8" plastic chucks, and generally a paddle switch. They can be had for cheap, and I'm thinking about picking up a pair (one for myself, one for the DIY kit I keep stocked at my parents' place), but I'm hesitant to if they've been superseded. The ones I've looked at all seem to have come out 6+ years ago. Nowadays I see there are right angled impacts, etc. out there. Is there a place in your toolbox for one of these (or multiple if you are like many of us here on TIA). Thanks crew!
JimboS1ice Posted July 22, 2016 Report Posted July 22, 2016 I have the m12 right angle, love it for awkward angles. Works great with pocket holes for tighter fitting spaces, defiantly would recommend a smaller 12v over a larger 18 Jimbo Sent from my iPad using Tapatalk 1
KnarlyCarl Posted July 22, 2016 Report Posted July 22, 2016 I have m12 right angle drill and impact. I've had to drill out a bolt and only could get my right angle drill in, wish I took a picture. Then had to tap/chase the threads out. Don't see that there was another way to do it, it was priceless. The right angle impact has also been huge help too, I can get in some tight areas around equipment and sinks. ... Sent from my XT1585 using Tapatalk 1
Grumpy MSG Posted July 22, 2016 Report Posted July 22, 2016 I don't use a ton, but I have the old 18V DeWALT (model unknown and I am too lazy to look). It comes out while working inside cabinets and boxes. I bought it as a bare tool, I think it was worth it. I suggest getting one in a battery line you already and either use it to add batteries to the line too or purchase a bare tool to minimize the price. 1
jeffmcmillan Posted July 22, 2016 Report Posted July 22, 2016 The drills are single speed so the torque and speed are mediocre for every application, and the impact drivers don't have space for a good impact mechanism in the head so they hardly have more torque or speed than the drills. Plus not a single brushless one. Some manufacturer is going to make a killing when they realize how easy it would be to make an awesome angle drill or impact. 1
Bremon Posted July 22, 2016 Author Report Posted July 22, 2016 They seem to be fairly inexpensive. I could get M18, M12 of 20v Max, as those are the platforms I have at this point. M18 head isn't any bigger than M12, RPM is twice as high, but has a slide pack hanging off its backside. M12 is slowest but has a stem pack, Dewalt is fastest, but doesn't seem to have the electronic clutch, and has a slightly bigger business end. Thanks for the video Knarly, that was pretty slick. Seems like the sort of thing that can get you out of trouble. The wrench version seems to overlap duty with the M12 ratchet. Like Jeff, I'm also fairly surprised no one has put out a brushless model. Not for run time, but for speed or torque.
The.Handyman Posted July 22, 2016 Report Posted July 22, 2016 I have the DeWalt 20v right angle drill and I use it a lot. Good LED, compact, multi-position grip and trigger, variable speed trigger, ect. I find I am using it in conjunction with my compact DCD790 drill all the time. I also have the Bosch 12v right angle drill that almost never use. Shame, really. 1
JimboS1ice Posted July 22, 2016 Report Posted July 22, 2016 When I use a right angle though I prefer a little less rom and power as you don't always have the pressure and leverage you need for higher torque and rom, just a preference really Jimbo Sent from my iPhone using Tapatalk 1
Bremon Posted July 22, 2016 Author Report Posted July 22, 2016 Hmm that makes sense. I could definitely see a brushless right angle impact wrench coming out with more than 60lb/ft though.
Logan Posted July 22, 2016 Report Posted July 22, 2016 I use Dewalts right angle adaptor that fits on any impact or dill 3
jeffmcmillan Posted July 22, 2016 Report Posted July 22, 2016 7 hours ago, Bremon said: They seem to be fairly inexpensive. I could get M18, M12 of 20v Max, as those are the platforms I have at this point. M18 head isn't any bigger than M12, RPM is twice as high, but has a slide pack hanging off its backside. M12 is slowest but has a stem pack, Dewalt is fastest, but doesn't seem to have the electronic clutch, and has a slightly bigger business end. Dewalt because it's dual speed
phffter Posted July 22, 2016 Report Posted July 22, 2016 cordless, i use them for tight access, like popping a hole into the framing at the top of 2 walls. of course, the tinner runs his duct in the way. have a stick makita with dead batteries. have a 12v dewalt, with dead batteries. i may pick up another. corded, a milwaukee 1/2 to drive hole saws when im doing a 'hot tap'. if the hole saw catches when it comes in contact with the pipe, AND the drill is positioned properly, it wont knock you in the snot locker. had a hole hawg grab, hit me in the chin, and i was out. at least i didnt fall off the ladder, my partner steadied me until i came to.
sparky603 Posted July 23, 2016 Report Posted July 23, 2016 I know a little bit about large right angle drills. As for smaller ones, never been powerful enough to really appeal to me, for my needs. I do however have both the M12 and M18 right angle impacts, which are great in combination with a stubby self-feeding spade bit for those odd instances. 1
Bremon Posted July 23, 2016 Author Report Posted July 23, 2016 Phffter, lucky that a coworker was there when your bell was rung, that's intense. Sparky, great family pic! How do you like the form factor of the Dewalt "stud and joist" drill in comparison to the hole hawg and super hawg form factor?
BababooeyHTJ Posted July 23, 2016 Report Posted July 23, 2016 I use Dewalts right angle adaptor that fits on any impact or dill Me too. I own an m12 right angle drill. That little adapter sees far more use. 1
KnarlyCarl Posted July 23, 2016 Report Posted July 23, 2016 7 hours ago, Logan p said: I use Dewalts right angle adaptor that fits on any impact or dill Yes, i see these everywhere, they work very very well 1
Bremon Posted July 23, 2016 Author Report Posted July 23, 2016 Interesting, the only thing I have like that is a Milwaukee that only offsets 30 degrees. Nice to get more utility out of fewer tools though; I like the looks of the new Dewalt impact attachment for snipping through sheet metal.
sparky603 Posted July 23, 2016 Report Posted July 23, 2016 1 hour ago, Bremon said: Sparky, great family pic! How do you like the form factor of the Dewalt "stud and joist" drill in comparison to the hole hawg and super hawg form factor? Thanks, Bremon! I've been using that older DeWalt there for about 20 years. Went with it because at the time it was the only large RA with bind protection, having a clutch that slips. I prefer the rat tail style of it for countering the counter torque, with it's length. Never found the need to use it with the side handle attached, just brace the rat handle against something when needed. To be honest, I haven't used that newer DeWalt all that much, as I got the M18 Hole Hawg soon after, and that instantly became pretty much all I use. I know the new cordless DeWalt will be that same form, so am guessing that's maybe why you ask. It is a really nice and powerful drill, and it has not only the mechanical clutch, but also electronic bind control. My preference to the other style is probably more just that I've had that one so long than anything. Well, that and that the newer DeWalt there doesn't always fit into places that the others will. I did score that DWD460 for $44 when Lowes clearance them out. 2
KnarlyCarl Posted July 23, 2016 Report Posted July 23, 2016 I would love to have a right angle drill that the shank of your bit can pass through the chuck into the back of the right angle head, so you can really get into tight spaces, and then as you drill further into whatever material, loosen the chuck, pull some more of the bit further and tighten it to drill some more. I would be impressed then. Basically instead of being limited to only getting as short as the back of the chuck will allow, have it pass through the back side of the right angle head
sparky603 Posted July 23, 2016 Report Posted July 23, 2016 23 hours ago, Bremon said: What I'm talking about is the range of models that seems to be saturated by right angle drills that have 100-200ish inch pounds of torque, 3/8" plastic chucks, and generally a paddle switch. The M12 right-angle impact has 600 in lbs of torque. It's 1/4" hex will hold even just 1" long bits. It's out in the truck, but I'm thinking that with saw a 1" phillips bit in it, you only need something just over 1.5" of clearance, so it'll get in some really tight places. Unless maybe if you're looking for something to drill metal with twist drills much more than you would be driving fasteners, I'd say impact is the way to go.
