JimboS1ice Posted September 29, 2016 Report Share Posted September 29, 2016 Made 1 cut and this is the result, now did I cut it like an asshole, ya I cut it full throttle so shame on me, but to shred 5 teeth of their carbide after 1 cut. So I posted this on Instagram and Diablo reached out to me which is cool of them even though it's partly operated error. Feedback I've got though a lot of people have never seen this with their blade... what do you guys think, do I blame the ridgid sawzall I never use or my eager thumb to tear through some metal?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Foneguy Posted September 29, 2016 Report Share Posted September 29, 2016 Really cool that diablo reached out ...... were you cutting some type of ........ anium ???? Jimbo slice workshop blade test .... cutting thru classified material ..... hmmmmm 1 Quote Link to comment Share on other sites More sharing options...
BMack37 Posted September 29, 2016 Report Share Posted September 29, 2016 I have a heavy trigger finger and cut a fair bit of metal for a non-professional...never had an issue with a Diablo Carbide, I love those blades. I really only use my Milwaukee metal blades on plastic now because the Diablos are soo good and durable. Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted September 29, 2016 Author Report Share Posted September 29, 2016 Appeared to just be standard steel nothing fancy, they are sending me a replacement blade and a return envelope for the damaged blade for testing [emoji1360] Diablo Sent from my iPhone using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
jeffmcmillan Posted September 29, 2016 Report Share Posted September 29, 2016 So these blades are an absolute godsend as diablo rightfully points out in some of their demos, but they're also very finicky. I never in my life thought I would be babying a sawzall or blade but I do now and it's totally worth it. The carbide teeth are incredibly prone to chipping and once you chip more than a little bit off of one the adjacent teeth chip pretty quickly too and the entire blade is shot. When you look at sawzall blades they're actually angled forward a bit which means if you run them too fast/without enough pressure the blade bounces in the cut a little and every time it lands the teeth chip a little. That's especially bad when it's a thin workpiece like the frame of a couch and it focuses all that impact on only a couple teeth. The angle thing is great for digging into the cut and counteracts the looseness of sawzall blade holders (otherwise the blade would be angled the other way) and bouncing doesn't damage bimetal blades but it kills carbide. The second worst thing is when you finish a cut and the blade hits something as it falls through. This is why the milwaukee ax wins over diablo carbide in demos where they have to cut a series of free nails because the blade falls from one nail to the next and breaks teeth (see the video below). As far as the couch, I think those are some pretty hard steel because I burnt up a milwaukee torch blade cutting through one. Unfortunately the diablo carbide blades didn't exist yet. I'm glad you brought this up because I've seen a lot of people kill these blades because you just don't expect to put effort into making a smooth cut with a sawzall and most don't even think to try using it differently. I used these to cut stock for a week while both shop bandsaws were broken and it's really hard to explain to people that a sawzall needs to be used as a precision tool. https://www.youtube.com/watch?v=6dd7fF1jRII You can see why I didn't want to type all this into the instagram box 2 Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted September 29, 2016 Author Report Share Posted September 29, 2016 So these blades are an absolute godsend as diablo rightfully points out in some of their demos, but they're also very finicky. I never in my life thought I would be babying a sawzall or blade but I do now and it's totally worth it. The carbide teeth are incredibly prone to chipping and once you chip more than a little bit off of one the adjacent teeth chip pretty quickly too and the entire blade is shot. When you look at sawzall blades they're actually angled forward a bit which means if you run them too fast/without enough pressure the blade bounces in the cut a little and every time it lands the teeth chip a little. That's especially bad when it's a thin workpiece like the frame of a couch and it focuses all that impact on only a couple teeth. The angle thing is great for digging into the cut and counteracts the looseness of sawzall blade holders (otherwise the blade would be angled the other way) and bouncing doesn't damage bimetal blades but it kills carbide. The second worst thing is when you finish a cut and the blade hits something as it falls through. This is why the milwaukee ax wins over diablo carbide in demos where they have to cut a series of free nails because the blade falls from one nail to the next and breaks teeth (see the video below). As far as the couch, I think those are some pretty hard steel because I burnt up a milwaukee torch blade cutting through one. Unfortunately the diablo carbide blades didn't exist yet. I'm glad you brought this up because I've seen a lot of people kill these blades because you just don't expect to put effort into making a smooth cut with a sawzall and most don't even think to try using it differently. I used these to cut stock for a week while both shop bandsaws were broken and it's really hard to explain to people that a sawzall needs to be used as a precision tool. You can see why I didn't want to type all this into the instagram box [emoji14] Great thoughts Jeff, the carbide actually seems brittle and it makes sense being the chipped teeth are not right against where they shoe was. I've posted some stuff on IG with another blade and the fuel sawzall and it didn't shred, metal could have been different as well as the RIDGID saw too, but I'm glad Diablo is sending me a replacement and they want a better look at the one I mucked up, maybe we will see a better product next round, good post!Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted September 30, 2016 Report Share Posted September 30, 2016 Good info Jeff, I've been using these blades right along, and holding my sawzall at half trigger, they eat right through the metal (black iron pipe) Quote Link to comment Share on other sites More sharing options...
SlingShotTools Posted October 28, 2016 Report Share Posted October 28, 2016 Hey guys check out Lenox Gold Power Arc Curved Metal Reciprocating Saw Blades. They cut through everything and last a long, long time. Quote Link to comment Share on other sites More sharing options...
