Details on 20v Concrete Nailer DCN890
JakeDewalt
43 minutes ago, The.Handyman said:
It's so nice to use too! The magnetic tip is excellent.
Why wouldn't you get the one with the magnetic tip? I don't see why not. If your shooting wood to concrete it's just a regular tip at that point.
Other question ion will this completely replace the need for a Ramset .27 ?
Not quite since the longest pins will be 2 1/4 so hang on to your Ramset for now. General rule of thumb is 1 inch penetration into concrete so if your nailing a 2 x 4, you still need a 2 1/2 inch pin
4 hours ago, Framer joe said:
Gotta be for metal stud plates ....it can’t help with framing ,but it’s got a place for some guys so that’s damn good....more tools more POWA always good !!
you could use it for nailing sill plates onto foundation?
Only metal I think he is saying
you can't do a PT 2x4 then the metal sole plate. Which is required where I live.
Metal cannot touch the slab
It doesn’t shoot nails long enough to nail a 2x6pt sill plate onto the foundation....besides that’s not code...a sill plate requires a “titen bolt” drilled in ,at least 5” into the foundation every 32” or a foundation bolt anchored 12” deep in the wall with a 2.5inch square plate and nut......
        ....it looks like it’s for metal stud guys amchoring a bottom plate
    Lee R.
    Lee R.
