BSquared18 Posted May 28, 2021 Report Share Posted May 28, 2021 (edited) Hello, The original battery pack that came with the B&D cordless drill that was built in 2006 is finally dying. Numerous similar-looking battery packs can be found on Amazon and elsewhere, but I'm not sure which one(s) is(are) compatible with the charger and drill that I have. The charger is built into a radio/drill stand. The battery slides onto the charger. The drill still works great. It would be a shame to have to trash it for a new one. Using the information provided below, can anyone suggest a battery that would be compatible with my charger and drill? I use Amazon Prime and would love to find one there. I can't be sure which one to choose. Thanks for your help, Bill Instruction Manual Catalog Numbers: Radio plus Charger: BDRC18, BDRC140 Cordless Drill: PS1800 Label on the Drill PS1800 10 mm Type 6 Use only with B&D HPB18 battery pack. Label on the Battery Pack: Use battery only with B&D chargers… 5102767-12.5103069-10/12 BDRC18 FS18C FSMVC Labels on the Charger/Radio Combination: Left-hand side label: Charge only 18V B&D Ni-Cd type power pack. Right-hand side label: BDRC18 Type 1 Battery Input: B&D 18Vdc Power Pack Battery Charger: Input: 21.3V ~60Hz 340mA Output: Charge: 21.7Vdc, 210mA; Trickle: 21.7Vdc, 80mA Edited May 29, 2021 by BSquared18 Improve spacing Quote Link to comment Share on other sites More sharing options...
BSquared18 Posted May 28, 2021 Author Report Share Posted May 28, 2021 By the way, am I correct that a drill that uses a Ni-CD battery isn't compatible with a Ni-Mh battery? Most of the ones I see at Amazon, etc. are Ni-Mh. One of the labels on my charger says, "Charge only 18V B&D Ni-Cd type power pack." Of course, in 2006, perhaps Ni-Mh wasn't available. Are they interchangeable? That would make my choices a lot easier. Bill Quote Link to comment Share on other sites More sharing options...
