Miguel Magalhães Posted March 13 Report Share Posted March 13 Hi everyone, I'm coming from a Stanley Fatmax Circular Saw which i couldn't perfectly put my blade at 90º nor use the bosch 30mm inside diameter disks i bought. I'm also using the Wolfcraft rail guides so the GCE model isn't a must. So i'm considering these models on title and i would like your opinion on build quality and precision when tunning the blade to work on a raild guide. I'm a ocasional diy user but i'm a perfectionist. Thanks for your input. MIguel Quote Link to comment Share on other sites More sharing options...
Altan Posted March 14 Report Share Posted March 14 Do you mean GKS 165?! Quote Link to comment Share on other sites More sharing options...
Miguel Magalhães Posted March 15 Author Report Share Posted March 15 It's this one https://www.bosch-professional.com/mz/pt/products/gks-65-gce-0601668900 Quote Link to comment Share on other sites More sharing options...
Altan Posted March 16 Report Share Posted March 16 I prefer the circular saws that the motor is on the right hand side, as I am right handed myself, most of the corded circular saws have the motor on the left which I don't like. So if you are left handed then you could consider the GKS 65 GCE as it has more powerful motor compared to the other one. But as much as I remember circular saws with 165mm blades have a 20mm bore and with 190mm blade have a 30mm bore. So I think the Bosch blade you bought is 190mm blade as you mentioned it has a 30mm bore. Quote Link to comment Share on other sites More sharing options...
