super Posted October 7, 2011 Report Share Posted October 7, 2011 Hello I want to know if there are a power tool with battery with a minimal noise? to cut wood?thanks Quote Link to comment Share on other sites More sharing options...
super Posted October 7, 2011 Author Report Share Posted October 7, 2011 Hi FriendsI can use to cut small woods with no noise the milwaukee copper tubing cutter 2471-21? or milwaukee m12 ppc? I use the milwaukee reciprocating saw m12 2420-22 but when cutting make a bigger noise.thanks Quote Link to comment Share on other sites More sharing options...
Eric - TIA Posted October 8, 2011 Report Share Posted October 8, 2011 Not sure why noise is an issue unless you you do work in clients home when they are sleeping like Dan does. The Milwaukee Copper tool is used to cut copper, not wood. I am not aware of any tool that is quite when cutting wood. 1 Quote Link to comment Share on other sites More sharing options...
PutnamEco Posted March 29, 2012 Report Share Posted March 29, 2012 Well, with a big enough battery, you could use either a water jet, or a laser. Not going to be cheap though....Die cutting can also be done without much noise, provided the material your cutting is not particularly thick. Quote Link to comment Share on other sites More sharing options...
