SevenOddosFence Posted March 11, 2016 Report Share Posted March 11, 2016 Does anyone here have either the Dewalt DW1648 or DW1649 ? If so how do You like the kit and does anyone know the best place to get them at decent prices ? Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted March 19, 2016 Report Share Posted March 19, 2016 Didn't recognize the part no. so I had to look it up, and they look very similar to the Milwaukee self feed bits, so similar I don't think I would be able to tell the difference. I've used the Milwaukee self feed bits like this and they work very well, they even sharpen up pretty well with a file after using them and hitting old nails or plaster, etc. Couldn't tell you where to buy though. Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted March 19, 2016 Report Share Posted March 19, 2016 Carl are you talking about the switchblades? you can replace the cutting edge on those Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted March 19, 2016 Report Share Posted March 19, 2016 28 minutes ago, JimboS1ice said: Carl are you talking about the switchblades? you can replace the cutting edge on those Uhh.. huhmm, it seems like the style I used was one that didn't have the replaceable blades, but I forget because whenever I cut a hole, I seem to just reach for my Lenox hole saws. But now that I researched the switchblades, that might be a purchase in my near future. Now that you say that, I remember talking to an electrician on a while back and he said about replaceable blades on these, but I never put two and two together or looked into it further. I know even less about the DeWalt variety, though, so that's all I can say Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted March 19, 2016 Report Share Posted March 19, 2016 yea having replaceable cutting edge for anything like this is pretty invaluable, you can always easily sharpen them blades 1 Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted March 19, 2016 Report Share Posted March 19, 2016 Well looks like I know what my next purchase will be. Sent from my SCH-I535 using Tapatalk Quote Link to comment Share on other sites More sharing options...
JRS5565 Posted March 20, 2016 Report Share Posted March 20, 2016 I have a set they work well kit comes with extra screw points and cutting blades. Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted March 23, 2016 Report Share Posted March 23, 2016 On 3/19/2016 at 7:17 AM, KnarlyCarl said: Well looks like I know what my next purchase will be. Sent from my SCH-I535 using Tapatalk Nope, never mind that. I'm not convinced I should get them. I like my Lenox hole saws too well, they don't require as big of drill (less torque) they don't make as much mess, I can go through nails several times a day with little trouble, and I can enlarge the hole saw I just cut by going at the hole at an angle, or grabbing my next size hole saw (it can be done with a self feed bit too, but it no longer self feeds at that point). I can start the hole saw at an angle if i'm trying to go through where some sheathing meets a wall plate. There have been times where I couldn't reach into the hole far enough with my hole saw to get through several layers of 2x lumber, and my extension was too long for going in between studs, I could take my 12" long 5/16" bit and poke it through to the other side of the layers of 2x and drill out my hole from the other side, having established a center point to do so. Self feeds bits don't work good in osb, where the center screw doesn't bite as well into osb as it does lumber. There are so many drawbacks to self feed bits of the larger diameter, that I've just stuck with my Lenox hole saws so far and been happy for it. I really like the smaller diameter self feed bits for smaller diameter water pipes, but the larger ones have too many disadvantages. There are many times that self feed bits are quite nice, don't get me wrong, but so far, I've really gotten into a good rhythm with my hole saws. Now I just need to take them to my lumber yard to get sharpened Quote Link to comment Share on other sites More sharing options...
