Looking for right hammer
Nsynewbie
I like something with a nice soft grip. If you are doing rough work you may want a milled faced hammer sometimes called checkered or waffle. For finish type work you may want a smooth faced hammer. The hammer I currently use is a stanley fatmax antivibe 22 oz hammer. The grip is a nice soft rubber and everything else is all steel which is very nice.  It has both a milled faced option and a smooth faced option. I have both options. They are around $20. I feel like the price is reasonable for what you get. I personally do not like wood handle hammers or curved claws but that is just my personal opinion. Eventually I wouldn't mind trying a Martinez Titanium hammer but they are pricey. Bottom line if you can only afford one hammer you should get a 16- 20 oz hammer with a rip claw and a smooth face. If you can afford 2 hammers I would go with a 22 oz with milled face and rip claw and a 16-20 oz with a rip claw and smooth face. Any other hammer is more specialty.
Estwing 20oz claw hammer is my favorite. Was my first hammer 9 years ago. Have been through 3 now though, not due to breaking. One was dropped in a lake from a dock project, couldn't recover it. The second one was stolen from a jobsite over a weekend. So now I'm on number 3. Great all around hammer, I find 20oz is the perfect weight for any situation.
Claw hammers are OK for wood but useless for just about everything else and the claw is so so on hail pulling. I carry a machinists hammer which has two flat hammer:
https://www.lowes.com/pd/Estwing-40-oz-Smoothed-Face-Steel-Machinists-Hammer/1000382011
This does 95% of the work. Others are a dead blow hammer for soft material,, aa planishing hammer and similar ones for sheet metal shaping if you do sheet metal work.and a spike maul for aiming at small targets. You use a spike maul by holding the narrow end on the spot you want to hit and hit the big end with the machinists hammer. For big jobs get a bigger hammer aka sledge hammer.
If I only had one hammer it would be a machinists. The second would be either dead blow or spike maul. Then a dead blow when needed.
If you need nail pulling, get a nail puller. If you're a carpenter then it's mostly nails so the straight head claw hammer makes sense. But I found my pry bar with a nail puller hole works MUCH better so I have no use at all for claws. So I only use it in a pinch if I'm doing carpentry.
Sent from my SM-T350 using Tapatalk
