alexjg- Posted September 6, 2020 Report Share Posted September 6, 2020 I’d like to use my Makita cordless drill to work on parts of my bicycle. Some of the bike’s components require a certain fastening torque (all measured in Nm). The drill has 11 graduations from 1-21 on the torque adjuster. I found in Makita’s spec, the maximum fastening torque to be 62Nm, but that’s the only value they give. I was wondering if anyone knew what scale Makita uses and how it translates to actual torque values measured in Nm. Quote Link to comment Share on other sites More sharing options...
Eric - TIA Posted September 6, 2020 Report Share Posted September 6, 2020 Great question and not sure. Something like this a while came up and I believe they reached out directly to Makita. I am sure they have a fact sheet they can share with you. So many manufacturers need specific setting so these power tool companies have that information. Quote Link to comment Share on other sites More sharing options...
HiltiWpg Posted September 16, 2020 Report Share Posted September 16, 2020 You really need a digital torque wrench. The ring clutch on a drill isn’t precise enough to rely on.Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
ToolFanJohn Posted September 18, 2020 Report Share Posted September 18, 2020 A cordless drill/driver isn’t especially accurate. A torque wrench will give you a better result. That being said, you could try calibrating your drill against a torque wrench and note down the Values. Alternatively you can put a long Allen key (or similar) in the chuck and measure how much weight the drill can lift. 1 Nm equates to 100 grams* at a distance of 1m, as does 1kg at 100mm, 2kg at 50mm, etc. So if your drill can lift 5kg at 100mm away from the drill shaft, that setting is delivering roughly 5Nm of torque. *its actually ~101.97, but 100 is close enough for practical purposes. 1 Quote Link to comment Share on other sites More sharing options...
