peroxwhygen Posted August 5, 2016 Report Share Posted August 5, 2016 Should I take the grease out(black gunk) and add more also can't find brushes Quote Link to comment Share on other sites More sharing options...
Atlas2000 Posted August 5, 2016 Report Share Posted August 5, 2016 Yes, remove the grease and replace with more modern equivalent. I don't know if they still make brushes specifically for this, but I have been able to get other brushes and sand them to size for similar projects. Good luck! Quote Link to comment Share on other sites More sharing options...
peroxwhygen Posted August 5, 2016 Author Report Share Posted August 5, 2016 These are the only things that look like brushes it is a long spring that can be pulled out and they hook on to the wire. What kind of grease should I use and would Homedepot have it Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
peroxwhygen Posted August 5, 2016 Author Report Share Posted August 5, 2016 Found lube how much should I add Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
