paulmars Posted August 23, 2016 Report Posted August 23, 2016 Set to A it starts fine and will run as long as it stays on A. however, move it to B and it revs up, then after 5 to 10 seconds it stalls. If i pump the throttle I can keep it running a few more seconds, but still it stalls. This exactly the same cold and hot. ideas? thanks, paul Quote
JimboS1ice Posted August 23, 2016 Report Posted August 23, 2016 What is it? Not up on ryobi model numbers, good shot it could be your air filter, check it out, see if it fires up without it Quote
paulmars Posted August 23, 2016 Author Report Posted August 23, 2016 was adjusting the carb screws and trying it and it kept stalling, then the last time i tried to start it, the cord jerked out of my hand. Now it wont pull at all. Its stuck, like the engine wont turn over. Let it cool and still cant pull the cord. What's wrong now? Quote
KnarlyCarl Posted August 24, 2016 Report Posted August 24, 2016 6 hours ago, paulmars said: was adjusting the carb screws and trying it and it kept stalling, then the last time i tried to start it, the cord jerked out of my hand. Now it wont pull at all. Its stuck, like the engine wont turn over. Let it cool and still cant pull the cord. What's wrong now? Oh boy, may be a bad sign, can you take out the sparkplug and try pulling the cord? Quote
Shadetree Posted February 2, 2017 Report Posted February 2, 2017 Paul I know how ya feel I got a ry802700a doing just like yours (hasn't locked up yet though)please let it be known if you come up with a fix thanks in addvance Paul (shadetree) Quote
