bozor Posted April 3, 2020 Report Share Posted April 3, 2020 I am trying to replace a damaged armature in a DWS520. I have stripped it down which was easy enough but I can't seem to get the armature itself out. I have tried: - wiggling it to see if it would loosen up - nope - tapping on a small piece of wood that i rested on the drive shaft - nope Annoyingly there doesn't seem to be any videos on how to do this either. Does anyone have any advice? Quote Link to comment Share on other sites More sharing options...
framer Posted April 4, 2020 Report Share Posted April 4, 2020 did you open up the gear case on the other end? Quote Link to comment Share on other sites More sharing options...
framer Posted April 4, 2020 Report Share Posted April 4, 2020 looks like a clip on other end of shaft. open the gear case. Quote Link to comment Share on other sites More sharing options...
bozor Posted April 6, 2020 Author Report Share Posted April 6, 2020 I did open the gear case but there was nothing inside to unclip/remove. Quote Link to comment Share on other sites More sharing options...
framer Posted April 7, 2020 Report Share Posted April 7, 2020 16 hours ago, bozor said: I did open the gear case but there was nothing inside to unclip/remove. you sure theres not a small snap ring at the base of that pinion shaft? Quote Link to comment Share on other sites More sharing options...
