Twoply Posted May 5, 2022 Report Share Posted May 5, 2022 When I try to use it, it just starts, and shuts off. It makes a soft grinding sound and shuts off after about a half blade revolution. The little LED lights turns on when I press the trigger. I can rotate the blade and it makes the same grinding noise. Not a sharp metal on metal grind, almost like a hard plastic on hard plastic - dull grinding. It gets fresh battery and still the same. I've removed the spindle assembly and it still does the same. No loose metal in there to indicate a stripped gear. I dont think the armature fins are dragging on anything. I did notice a wire's insulation was rubbed raw. As I separated all the wires, it started to run for about 2 revolution, then die again. The battery almost feels like it's drained because it will stop even trying after a few tries. If I let it rest, it will start again. The little black resister gets pretty hot while I'm attempting to operate this thing. Help! Thanks in advance. 1 Quote Link to comment Share on other sites More sharing options...
Twoply Posted May 5, 2022 Author Report Share Posted May 5, 2022 Quote Link to comment Share on other sites More sharing options...
