pjenni9550 Posted October 1, 2012 Report Share Posted October 1, 2012 Have new out of the box 735 planer is supposed to plane down to 1/8". Have completed set up from owner manual. I have cranked head up beyond 2", set minimum to 1/8", then when I crank head down, will only go to 3/4". De Walt want me to take to nearest De Walt service center which is over 100 miles (one-way). Anyone have an idea to fix. Quote Link to comment Share on other sites More sharing options...
matchit Posted October 2, 2012 Report Share Posted October 2, 2012 Did you try rotating the dial on the front bottom corner? I believe there are 3 different heights. Quote Link to comment Share on other sites More sharing options...
pjenni9550 Posted October 2, 2012 Author Report Share Posted October 2, 2012 yes, thank you, I have it set to lowest setting Quote Link to comment Share on other sites More sharing options...
stanford1621@gmail.com Posted October 16, 2012 Report Share Posted October 16, 2012 I bet your set stop is set wrong, it is the bolt in the picture under the depth knob, get a 1/2" wrench and loosen the not that is on it then lower it and all the way down, then get an 1/8" board set it in the planer lower the head until it just touchs the board then raise the set stop while your depth knob is set to 1/8" you can also do ir with an 1/4", 1/2" 3/4" just set your depth dial accordingly. Quote Link to comment Share on other sites More sharing options...
