DPSElias Posted March 14, 2014 Report Share Posted March 14, 2014 Looking at these specs they don't look all that different, speed is the same for both gears, both brushless, and have same torque rating, only major difference I see is the "Chucks" Thought Screwdrivers were suppose to be slow speeds for more control, so what is the benefit of the screwdriver over the drill? Looking to possibly get a few M12 fuel tools to expand my Specialty tools. Quote Link to comment Share on other sites More sharing options...
DR99 Posted March 14, 2014 Report Share Posted March 14, 2014 You get 50 foot pounds more torque and a quick load bit holder. It's also more compact because it doesn't have a chuck adding length. Quote Link to comment Share on other sites More sharing options...
Javier Posted March 14, 2014 Report Share Posted March 14, 2014 It seems like the m12 fuel screwdriver and drills all use the same motor. You're right the only real difference is the chuck. It comes down to what do you need. The screwdriver offers the convenience of the fast hex chuck and shorter length but then your limited to only hex bits.Screwdrivers are getting faster. The single speed dewalt 12v max is 1000rpm I believe and all seem to be a huge leap from the original m12 screwdriver. If the second speed is too fast in the fuel screwdriver you can always use speed 1 Quote Link to comment Share on other sites More sharing options...
dwain Posted March 15, 2014 Report Share Posted March 15, 2014 yep, i just got the Dewalt 12V max screwdriver, and its somewhere around 1000rpm. Really handy for indoor and fine work. The 20V impact driver and 12V drill are going to get a lot less work now .... Recommend the tool type... Quote Link to comment Share on other sites More sharing options...
