wood chisels...
1R954Baker-hvac
I have the Neiko 9 chisel set. While they are not considered high end chisels by any means, I am quite pleased with them. I cut a 3" through mortice in hard maple using the 1/2" chisel (mallet head) and found the chisel was still sharp afterwards. If you do a search on Amazon you will find them for under $50. The Irwin chisels are no longer produced in England and aren't as good as they used to be.
If you looking for good quality wood chisels but don't want to shell out $75 a pop for Lie-Neilson or Veritas, I would by Narex Chisels from Lee Valley.
http://www.leevalley.com/US/Wood/page.aspx?p=67707&cat=1,41504
They are a great set of chisels. They hold an edge great and will rise to any challenge that you can throw at them. My second suggestion is to get the 4pc. set for $45 because in reality you don't need 7 different width chisels. Save the money for another tool that you would get more use/value out.
IE a couple Narex mortis chisels. http://www.leevalley.com/US/Wood/page.aspx?p=66737&cat=1,41504
If I where making the purchase I would get the set of 4 bevel chisels and a 1/4" and 1/2" mortise chisel.
    Powerlineman1976
    Powerlineman1976
