Dan2425 Posted September 15, 2015 Report Posted September 15, 2015 (Check Files attached for pictures to see what i'm talking about throughout the review)To start off im going to go over the features and "claims" from Milwaukee about what this tool can do over a plain old markerClog Resistant Marker TipWrites through Dusty, Wet and Oily SurfacesDurable Marker Tip for Writing on Concrete, OSB and Rough Surfaces For this Review I will be testing this marker on a sheet of metal. As you can see in the 2nd picture it is very dusty! In the 2nd picture i marked off a section with the inkzall where its perfectly clean (so it should work just like any other brand of marker). In the 3rd picture you can see a section where it is dusty and the marker went right through the dust and put a nice clean mark on the metal. Now in the 4th picture I used a Gun oil and wiped it down but left a little bit. (didn't mark it when there was a puddle of oil) As you can see with a small amount left it will still mark the metal. As for the 5th Picture i used 15W40 Diesel engine oil and what you see is a puddle that the Milwaukee Inkzall penetrated through!!!! and in the 6th picture i wiped it down til there was a little bit of diesel oil left and they all marked it perfectly. Pros:Well BuiltWill penetrate through the toughest oilsHas a spot to hang from a lanyardYou can clip it to your hard hatColors are Very Bright and easy to seeWill not roll away on you while you are busy workingWorks Great on metal Cons:I Would have liked to have seen a white colored markerAll of the 4 colors don't show up well on darker colored metals and painted surfaces Pricing and where to buy:Home Depot 4.69 http://www.homedepot.com/p/Milwaukee-Inkzall-Fine-Point-Multi-Colored-Markers-4-Pack-48-22-3106/205430399 Tool Barn 4.65 http://www.toolbarn.com/milwaukee-48-22-3113.html?psrid=100522062 CPO 9.99 http://www.cpomilwaukee.com/milwaukee-48-22-3106-inkzall-fine-point-colored-jobsite-marker-set-4-pack/miln48-22-3106,default,pd.html?ref=cj
HiltiWpg Posted September 15, 2015 Report Posted September 15, 2015 Mine dried out in under 5 months. Bone dry inside a veto tool bag. I should specify, I was only using one, the others stayed in the bag with the caps on.Sent from my iPad using Tapatalk
Dan2425 Posted September 15, 2015 Author Report Posted September 15, 2015 Hmm.... there is a limited lifetime warranty on the marker just to let you know. I'd call Milwaukee and see if you can get a new one.
Atlas2000 Posted September 16, 2015 Report Posted September 16, 2015 Impressive, but I try to keep my projects a little cleaner. Maybe because I never had one of these markers!
JimboS1ice Posted September 24, 2015 Report Posted September 24, 2015 So I've had mixed feelings on the inkzall, the skinny ones seem to work better in wet conditions than the fatter version. I purchased these for use at my job where I am a butcher so naturally I had to test them out using them on bloody cardboard, beef blood that is. Needless to say it didn't write but I have noticed that it writes rather well on dusty lumber.JimboSent from my iPhone using Tapatalk
