1,476 -
17
Posts posted by dwain
Possibly the temps in battery or tool were getting too high and the protection kicked in. I'm not sure if it contributed, but a larger battery pack would definitely have taken longer to heat up...
Other than what I mentioned I'd like to get the cut out tool and drywall gun.
Ahh those tools are a bit more specialty, and not likely on Milwaukee's radar I suspect. Dewalt 20V has those though, and brushless too.
If you're going to switch, I'd at least wait until the batteries have status gauges on them, as that will feel like a downgrade from Milwaukee's 4 bars...
1
Glad you're ok Conductor. I've been on the lookout for a deal on a chop saw. I might re-think that now ....
you're crazy. the fuel circ saw is just as good, if not better (IMO). the td148 is awesome, but fuel rev 2 is very close. Not sure what difference is between the jigsaws. In many other categories, Red is better.
Unless there are several tools in makita you can't get in Milwaukee, you'd be crazy to switch. For me, they are the best 2 of the main brands.
I assume then they say '10" channel lock' pliers they mean tongue & groove pliers, and CHANNELLOCK really are the best by all reports
I also swear by the Channellock adjustable wrenches (wideazz), they're awesome. If you need one.
Their multi-tool is already top of the heap, despite being brushed.
1
Smaller wheels are perfectly safe since they'll be rated for a higher RPM, but it generally won't be as effective.
to clarify this, a 4" disc in a 5" grinder is just as effective as in a 4" grinder. But the 5" disc will get better depth of cut.
1
I have a slimline 5" bosch and its been great. If its for concrete use, bigger disc and more power are what you should chase...
Why don't you post the list? I'm sure members would be able to give better recommendations then
Jason has recommended good (premium) brands above. Maybe you would also like to hear of some good-value budget tools that you'll still get years of use from?
Yeah, they're pretty popular here in the US. Is it safe to use 4 1/2" wheels, blades, etc in a 5" grinder? 4 1/2" stuff is way more readily available than 5".
As long as the arbor/spindle is the same size (it looks like they are), absolutely! After some cuts a 5" disc is only 4-1/2" in diameter anyway
But if the 5" is more expensive, and your always going to be buying 4-1/2" discs anyway, not much point.
Do people usually go for 4-1/2" grinders in the US? Our electric grinders are 4" or 5", and I always recommend the 5" for that extra bit of cut depth, without increasing the size of the unit (like a 7")
Milwaukee and Makita both have cordless planers:
http://www.toolbarn.com/milwaukee-2623-20.html?gclid=CPfsl-LGk8gCFQ6oaQodZnoDpA&ad=54712193894
As do Bosch, Hitachi & Ryobi. Ryobi's is only 2" width though.
The other 18v products (impact driver, wrench and compact drill) are quality but no where near the engineering of the 4-Speed drill. I'd happily own them, but I would NOT pay FEIN prices for them. They won't keep up with the latest models from regular brands.
I know what I said and apologized for any confusion. Did you really think I meant V*Ah=W and not Wh?
So thanks for feeling like you had to correct me a second time?
No offense intended. Just on your reply you didn't acknowledge the actual correction (W.h.). This being a forum, with many readers, I like to help people understand correctly, as others have often done for me.
It's all good!
I hope no one was confused, I specified amp hours. I just assume most understand battery capacity, my bad.
And yes, Hilti does have an additional cell.
I think most around here understand that Amp hours (Ah) are a measure of battery capacity. But in fact, they are only a measure of battery capacity for a given voltage (most often 18v). A 10Ah battery on a 6V tool would still have far less total juice than your Hilti.
I was actually correcting your use of the term '112 Watts'. The battery is not 112W, but 112 Watt hours in capacity (21.6V x 5.2 Ah = 112Wh)
I used 2 freshly charged 5.2's and by the end of the day, my impact is at 4 bars, the drill is at 3 bars. Damn.
112 watts for the 5.2ah, very impressed. Same size and weight as the 3.3ah. Compared to a Milwaukee 5.0ah (90 watts) it's a noticeable difference in runtime.
You mean Watt hours (Wh), 112 Watts would be a very weak drill. Watts is an instantaneous measure of power.
Watts hours are a measure of total juice, and the formula is just voltage x Ah.
Wow, the tool is 21.6V. It must have an extra cell per layer (i.e. 12 cells instead of 10). Of course those are just specs. The efficiency of the drill and electronics of the system could also be contributing to superior runtime.
Haha, buy two of them Dwain and let me keep one and I will send it over to you in Australia!! I will just have to declare it as rocks though for customs. That is insane the price difference though!!
the exchange rate makes up most of it in this case (compared to regular price).
i don't know how much it would cost to post to Aus, but if someone were giving an Aussie TIA friend a hand (through ebay maybe) ....
If I get this I'm going to have to ditch the Ryobi I have in my office and replace it with this one.
slight upgrade
1
Dewalt has finally listened!!
wow, never thought I'd see the day. Wonder why they've waited so many years though?
you guys used one of these flush cut blades?
http://www.amazon.com/DEWALT-DW3311-Flush-Cut-Blade/dp/B000R8GVMG
i just ordered one, gonna buy super handy.
Love the recip blade tip too!
so whats the next hot tools coming out by dewalt?
in Dewalt
Corrected.
