peroxwhygen Posted July 31, 2016 Report Share Posted July 31, 2016 Driving 1/4x1 1in into maple which mode to pick when using either the dewalt or Milwaukee Impact driver also do you make the whole a size smaller then the screw? Buying one next week not sure which one Iam getting it will be based on price Quote Link to comment Share on other sites More sharing options...
khariV Posted July 31, 2016 Report Share Posted July 31, 2016 A 1/4"x 1" lag screw isn't really all that long so I'm quite certain either the Dewalt or the Milwaukee will work out just fine. What may I ask are you using such small lag screws for that you couldn't use a different wood screw? Maple is hard so you'll definitely want to pre/drill to keep it from splitting. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
peroxwhygen Posted July 31, 2016 Author Report Share Posted July 31, 2016 I know both drills has 3 modes so How fast should I set the drill too? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted July 31, 2016 Report Share Posted July 31, 2016 Medium would be probably he best just to make sure you don't over drive or crack the wood, make sure to drill a pilot hole and a little soap on the screw, bar soap that is, wouldn't hurt... What are you fastening? Jimbo Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
peroxwhygen Posted July 31, 2016 Author Report Share Posted July 31, 2016 Workbench table top to legs Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Grumpy MSG Posted August 1, 2016 Report Share Posted August 1, 2016 For your pilot holes, look at the shaft of your lag screw, not the outside of the threads. you want your pilot hole about the same size as the shaft, or a hair smaller. That will give you the maximum wood for the threads to grab. Drill it a little deeper than the length of the screw it will allow for a little sawdust to be pushed forward of the screw. 2 Quote Link to comment Share on other sites More sharing options...
Kato Posted August 1, 2016 Report Share Posted August 1, 2016 3/16" drill bit for 1/4" lags. Quote Link to comment Share on other sites More sharing options...
jeffmcmillan Posted August 2, 2016 Report Share Posted August 2, 2016 Kato is right on 3/16 pilots. With lags I go with top speed but usually much larger lags too. Quote Link to comment Share on other sites More sharing options...
