olletsocmit Posted August 22, 2016 Report Share Posted August 22, 2016 Hey guys not sure if this is a big deal or not but I've been noticing over the past few months that my fuel drill is starting to wobble almost like an impact driver does. it was perfect when I first got it but seems to be getting worse. It's not just with this longer extension it's with drill bits, my hole saws, even small or short bits too... I originally thought then a few things were bent but they are not. Everything on the drill seems tight, is this normal for an eight month old drill that's used around the house for DIY? I have attached two videos below, let me know if anyone needs to see anything else. https://youtu.be/wRZ5Bp-vENM https://youtu.be/75b0YpFFyM4 Quote Link to comment Share on other sites More sharing options...
StrippedScrew Posted August 22, 2016 Report Share Posted August 22, 2016 Should have went Dewalt Yeah they seem to be a bit of wobble. Is it noticeable when using the drill? Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted August 22, 2016 Report Share Posted August 22, 2016 Worth a shot on warranty Quote Link to comment Share on other sites More sharing options...
jeffmcmillan Posted August 22, 2016 Report Share Posted August 22, 2016 Each jaw in the chuck has two little carbide inserts that grip the bit so one of those probably chipped or shifted. It's not something you can fix so just go for the warranty. This is strange because I've heard a lot about new M18 drills having wobble but never one developing it after a while. Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted August 22, 2016 Report Share Posted August 22, 2016 34 minutes ago, jeffmcmillan said: Each jaw in the chuck has two little carbide inserts that grip the bit so one of those probably chipped or shifted. It's not something you can fix so just go for the warranty. This is strange because I've heard a lot about new M18 drills having wobble but never one developing it after a while. We've had quite a few cases of m18 wobbles get posted around here, had a Bosch drill wobble pretty bad Quote Link to comment Share on other sites More sharing options...
