eddie1976 Posted December 11, 2016 Report Share Posted December 11, 2016 I just got a 12" Kobalt sliding miter saw and need a stand. Found a Ryobi for $60 at HD. Got it home, but found out that Ryobi doesn't recommend using it with anything bigger than 10" sliding miter. I don't want to spend alot of $ on a stand, any recommendations? Quote Link to comment Share on other sites More sharing options...
kruton Posted December 11, 2016 Report Share Posted December 11, 2016 My Home Depot has the Ridgid stand for 149 right now. It was 99 on black friday. May drop down again if you are willing to wait. It's still a pretty good stand at 149 in my opinion.Sent from my SM-N900V using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
comp56 Posted December 11, 2016 Report Share Posted December 11, 2016 23 minutes ago, eddie1976 said: I just got a 12" Kobalt sliding miter saw and need a stand. Found a Ryobi for $60 at HD. Got it home, but found out that Ryobi doesn't recommend using it with anything bigger than 10" sliding miter. I don't want to spend alot of $ on a stand, any recommendations? give craig's list a try, or Kijiji I see them on there cheap from time to time and are usually not used much so you get a good deal on something that either works or it is broken......no guessing if it going to burn up 15 minutes after you get home.... Quote Link to comment Share on other sites More sharing options...
eddie1976 Posted December 11, 2016 Author Report Share Posted December 11, 2016 11 minutes ago, comp56 said: give craig's list a try, or Kijiji I see them on there cheap from time to time and are usually not used much so you get a good deal on something that either works or it is broken......no guessing if it going to burn up 15 minutes after you get home.... Not much to burn up....I already have the saw, just looking for the stand. Quote Link to comment Share on other sites More sharing options...
comp56 Posted December 11, 2016 Report Share Posted December 11, 2016 18 minutes ago, eddie1976 said: Not much to burn up....I already have the saw, just looking for the stand. that is what I mean when your buying the stand only nothing is electrical to burn up or die on you I would take a chance buying used Quote Link to comment Share on other sites More sharing options...
eddie1976 Posted December 11, 2016 Author Report Share Posted December 11, 2016 Thanks for the comments guys. Quote Link to comment Share on other sites More sharing options...
Conductor562 Posted December 11, 2016 Report Share Posted December 11, 2016 I was happy with the Ridgid stand, I just couldn't stand the saw ? 1 Quote Link to comment Share on other sites More sharing options...
Jronman Posted December 12, 2016 Report Share Posted December 12, 2016 @eddie1976 would building your own stand work? Quote Link to comment Share on other sites More sharing options...
rfwjr Posted December 12, 2016 Report Share Posted December 12, 2016 I bought the Delta stand for $149, the Ridgid was $199 at the time and they look almost the same. I have a Bosch 12 inch GCM12SD on the Delta and it works fine. 2 Quote Link to comment Share on other sites More sharing options...
SevenOddosFence Posted December 12, 2016 Report Share Posted December 12, 2016 21 hours ago, rfwjr said: I bought the Delta stand for $149, the Ridgid was $199 at the time and they look almost the same. I have a Bosch 12 inch GCM12SD on the Delta and it works fine. I noticed that - the stands look exactly the same Quote Link to comment Share on other sites More sharing options...
Kato Posted December 12, 2016 Report Share Posted December 12, 2016 I'd be curious to know why the Ryobi isn't able to hold a 12" saw. It's rated for 400 pounds (according to their site), a 12" miter saw and the wood you're cutting isn't going to weight that much. I have a Ryobi stand and it seems pretty beefy, kinda curious as to why they'd say it couldn't hold a 12"... Quote Link to comment Share on other sites More sharing options...
eddie1976 Posted December 13, 2016 Author Report Share Posted December 13, 2016 4 minutes ago, Kato said: I'd be curious to know why the Ryobi isn't able to hold a 12" saw. It's rated for 400 pounds (according to their site), a 12" miter saw and the wood you're cutting isn't going to weight that much. I have a Ryobi stand and it seems pretty beefy, kinda curious as to why they'd say it couldn't hold a 12"... As I have been reading and learning (more than I ever wanted to) about this subject it appears the issue is related to stability rather than total weight. I guess the slider coming forward or back off the stand might make it unstable and have it tilt forward or back, causing it to fall. I don't know how true that is, but many of the stands aren't recommended for 12" sliding saws. If you want one, you need to upgrade to a bigger one, for alot more money. The one I bought is $60, but the ones that are recommended for 12" sliders are about $150. I will try to use the one I have and see how it feels. If it doesn't feel steady or stable, I will take it back and cough up the extra money. Quote Link to comment Share on other sites More sharing options...
