olletsocmit Posted February 17, 2017 Report Share Posted February 17, 2017 I was just at Home Depot and scored two bottles of Zep drain opener for a dollar each! Are used drain cleaner years ago but haven't in a long time. I hear a lot of people when I'm in the plumbing Aisle talk about how this kind of stuff is bad for your plumbing and can eat away at plastic and rubber and that kind of thing.Does anybody know if this kind of stuff really is bad for your pipes and you should avoid it and only use it as a last resort? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
DR99 Posted February 17, 2017 Report Share Posted February 17, 2017 I think your ok with pvc for the most part. Some of the old steel and cast iron pipe could get fucked up by using it too much. Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted February 18, 2017 Report Share Posted February 18, 2017 Acid is most corrosive on metals, I stay away from any stain cleaner, best tactic I've found for flushing slow draining lines out is extremely hot water and bleach, just don't inhale Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted February 18, 2017 Report Share Posted February 18, 2017 It's rare I come across a situation where the drain cleaner like this actually worked, it's almost always something permanently damaged or a sagging pipe or cast iron that acts like Velcro as waste from a kitchen sink tries to drain through... That Velcro effect is from old cast iron pipes and doesn't just go away from liquid drain cleaner.... In the one instance it did work, no one really knows what happened but it was newer plumbing and something may have got caught up on a fitting, I may never know, or the problem may return. If you bought it for that cheap, you're not losing much at all, try it and worse case is it doesn't help, then you gotta get the drain auger out Quote Link to comment Share on other sites More sharing options...
Jronman Posted February 22, 2017 Report Share Posted February 22, 2017 my kitchen drain seems to clog a lot. The disposal also shoots water up the drain on the other sink. Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted February 23, 2017 Report Share Posted February 23, 2017 13 hours ago, Jronman said: my kitchen drain seems to clog a lot. The disposal also shoots water up the drain on the other sink. When I hear that around here, it's almost always old iron drain pipes. Only other thing it's been is poorly installed drain lines that sag and accumulate waste, blocking the flow. If it's the former, snake it out and hope you get through. If the latter, it needs fixed. The old iron pipe will need replaced at some time, no getting around that, if that's what you have Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted February 23, 2017 Report Share Posted February 23, 2017 When I hear that around here, it's almost always old iron drain pipes. Only other thing it's been is poorly installed drain lines that sag and accumulate waste, blocking the flow. If it's the former, snake it out and hope you get through. If the latter, it needs fixed. The old iron pipe will need replaced at some time, no getting around that, if that's what you haveI hate old cast pipes, few months ago I finally got all the plumbing updated in my parents houseSent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted February 24, 2017 Report Share Posted February 24, 2017 7 hours ago, JimboS1ice said: I hate old cast pipes, few months ago I finally got all the plumbing updated in my parents house Sent from my iPhone using Tapatalk Good on you dude, that's my bread and butter haha In many places cast is still required for fire reasons. it doesn't burn like pvc can. I'm talking hospitals and institutions Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted February 24, 2017 Report Share Posted February 24, 2017 Good on you dude, that's my bread and butter haha In many places cast is still required for fire reasons. it doesn't burn like pvc can. I'm talking hospitals and institutions Ya more commercial and industrial code requires that, you'd have a field day in my neck of the woods, tons of house built with cast all pre 1960Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted February 24, 2017 Report Share Posted February 24, 2017 9 minutes ago, JimboS1ice said: Ya more commercial and industrial code requires that, you'd have a field day in my neck of the woods, tons of house built with cast all pre 1960 Sent from my iPhone using Tapatalk Same here ha My sister bought a house recently and there's bubbles forming on the cast iron that ooze out liquid ever so little then dry up and you poke them(with a knife, that's sewage yo) and it starts dripping.... She was not happy to find that out but hey at least i taught her to see the warning signs lol Quote Link to comment Share on other sites More sharing options...
