gbsk Posted June 1, 2019 Report Share Posted June 1, 2019 I have a Makita worm drive saw Model #.5007NB. The plate will not lock because there is a bolt head on the locking adjustment mechanism that will not tighten. Yjr lt heaad will not turn when I try to tighten it with a wrench. How can I get this tight? Thanks, GB Quote Link to comment Share on other sites More sharing options...
CATERPILLAR Posted July 4, 2019 Report Share Posted July 4, 2019 Pop off the c clip , take off the lever then tighten the nut until it is tight enough to hold but not too tight that you can't use the lever to loosen it. Then put the lever back on and pop the c clip back on. Quote Link to comment Share on other sites More sharing options...
