Ricodylan13 Posted April 6, 2021 Report Share Posted April 6, 2021 Hello all, I just bought a Milwuakee M18 3/8" impact wrench. I just bought a set of Husky impact sockets in Metric/SAE. The sockets snap into place but seem to be loose once they are attached. I'm not familiar with impact drills and I feel like the sockets are not supposed to be seated that loosely. Can someone advise me as to which sockets I am supposed to get? Or is it normal for the sockets to sit that loose? Thank you! Quote Link to comment Share on other sites More sharing options...
Biggie Posted April 7, 2021 Report Share Posted April 7, 2021 They really should fit tight sometimes when the impact is new the hogring can be stiff and it's possible you're not getting the socket pushed on quite far enough. It could also be possible that there's some goofy tolerance issue between the impact and socket but that's not real common as most sockets and impact wrenches should be universal. I have an old m12 ⅜" impact wrench and some chrome sockets don't always fit right on it but never have a problem with impact sockets. Quote Link to comment Share on other sites More sharing options...
Ricodylan13 Posted April 7, 2021 Author Report Share Posted April 7, 2021 12 hours ago, Biggie said: They really should fit tight sometimes when the impact is new the hogring can be stiff and it's possible you're not getting the socket pushed on quite far enough. It could also be possible that there's some goofy tolerance issue between the impact and socket but that's not real common as most sockets and impact wrenches should be universal. I have an old m12 ⅜" impact wrench and some chrome sockets don't always fit right on it but never have a problem with impact sockets. So they sockets are definitely "snapping" past the hogring and they don't come off without some force. The issue I see is once I start drilling, the socket sort of oscillates in a weird way. The bit doesn't fly off when I go full speed and my carpenter friend said he sees sockets all the time that sort of wiggle around once in place. I don't need a perfect fit, I just don't wanna waste $60 on sockets that will yield poor results. Quote Link to comment Share on other sites More sharing options...
Biggie Posted April 8, 2021 Report Share Posted April 8, 2021 Sounds like what you're describing is probably pretty normal although it's hard to say without seeing it. Might just be some tolerance difference between the sockets and impact. I know I have some cheap sets of harbor freight sockets that wobble pretty good when they aren't on a bolt but they've never been a problem when in use. Quote Link to comment Share on other sites More sharing options...
Ricodylan13 Posted April 8, 2021 Author Report Share Posted April 8, 2021 10 hours ago, Biggie said: Sounds like what you're describing is probably pretty normal although it's hard to say without seeing it. Might just be some tolerance difference between the sockets and impact. I know I have some cheap sets of harbor freight sockets that wobble pretty good when they aren't on a bolt but they've never been a problem when in use. Ok that makes me feel better. I didn't want to spend the $60 on the Milwuakee sets and went with Husky instead. I haven't tried the sockets yet but I'm hoping that wobble won't come into play once I start actually using it. I don't need to buy sockets specifically for a hog ring right? The set has the little dimples for the detent pin but I have a hog ring, I assume it should work either way. Quote Link to comment Share on other sites More sharing options...
Biggie Posted April 9, 2021 Report Share Posted April 9, 2021 Nope there's no special socket for a hog ring. I don't think anyone even makes a 3/8" drive impact wrench with anything but a hog ring. Quote Link to comment Share on other sites More sharing options...
Weld ON Posted April 18, 2021 Report Share Posted April 18, 2021 Standards sockets and bits are made of premium material if set was cheap , if you using brands like sonic,facom,george and other world know brands that good but not suitable for impact wrench or any other imact tools. You must have impact bit set and 100% is black oil oxid finished. That is not about tolleranc that is about material , if you will do slow motion then you will see how socket,drill etc is trying to twist , when you have org. impact stuff then you can pass all forse without twisting. That is like you have long extension for bit and before you removing any bolt you can see how is twisting. If you use standard socket for impact then resonation is to HIGHT and socket is not able to keep frequency as is on imact tool and the is running on more hight freq. and then you can see danage inside square hole ,for sure imact end is more hard as standard or impact socket ... Quote Link to comment Share on other sites More sharing options...
