Altan Posted April 9, 2022 Report Share Posted April 9, 2022 1/4" hex shank to square female, adapter for taps in different sizes. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 9, 2022 Author Report Share Posted April 9, 2022 1/4" hex shank internal & external threaded adapters. The internal threaded adapters are made by Wera and Athlet also. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 9, 2022 Author Report Share Posted April 9, 2022 Wera ones are much better quality Quote Link to comment Share on other sites More sharing options...
Altan Posted April 9, 2022 Author Report Share Posted April 9, 2022 Athlet ones Quote Link to comment Share on other sites More sharing options...
wingless Posted April 9, 2022 Report Share Posted April 9, 2022 1 hour ago, Altan said: 1/4" hex shank to square female, adapter for taps in different sizes. These are cool, but confusing to me. When I want to do taps w/o the tee handle or the bar tool included w/ the kit, I have eight point sockets w/ either ¼" or 3/8" standard drive. Those fit my taps. The image shows a M14 laser engraved ID, assuming for the square drive dimension. Are the ROW taps not having the US fractional inch square drive? Who is the manufacturer on this tool? Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 37 minutes ago, wingless said: These are cool, but confusing to me. When I want to do taps w/o the tee handle or the bar tool included w/ the kit, I have eight point sockets w/ either ¼" or 3/8" standard drive. Those fit my taps. The image shows a M14 laser engraved ID, assuming for the square drive dimension. Are the ROW taps not having the US fractional inch square drive? Who is the manufacturer on this tool? 1/8x Screw Tap Socket Adapter Driver 1/4 Hex Shank Thread Tapping Sleeve Holder | eBay 1 Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 41 minutes ago, wingless said: These are cool, but confusing to me. When I want to do taps w/o the tee handle or the bar tool included w/ the kit, I have eight point sockets w/ either ¼" or 3/8" standard drive. Those fit my taps. The image shows a M14 laser engraved ID, assuming for the square drive dimension. Are the ROW taps not having the US fractional inch square drive? Who is the manufacturer on this tool? It seems they are made in Taiwan. Currently not made by Western brands. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 43 minutes ago, wingless said: These are cool, but confusing to me. When I want to do taps w/o the tee handle or the bar tool included w/ the kit, I have eight point sockets w/ either ¼" or 3/8" standard drive. Those fit my taps. The image shows a M14 laser engraved ID, assuming for the square drive dimension. Are the ROW taps not having the US fractional inch square drive? Who is the manufacturer on this tool? I am not too familiar with Inch thingies in general, I did a search on eBay and I could just see them in Metric. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 12 hours ago, wingless said: These are cool, but confusing to me. When I want to do taps w/o the tee handle or the bar tool included w/ the kit, I have eight point sockets w/ either ¼" or 3/8" standard drive. Those fit my taps. The image shows a M14 laser engraved ID, assuming for the square drive dimension. Are the ROW taps not having the US fractional inch square drive? Who is the manufacturer on this tool? Quote Link to comment Share on other sites More sharing options...
wingless Posted April 10, 2022 Report Share Posted April 10, 2022 Thanks for these, but zero use for the US. The taps available in the US have SAE fractional inch square drives, none have metric square drives. My current solution is using eight point sockets that fit my ¼" drive tools. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 What I would like to get is this service key in 4 different pieces with 1/4" E6.3 hex shank. I started to search for 1/4" hex shank square and triangle female adapters and I found this instead. I know Wiha makes triangle nut setters like a screwdriver but not as a bit(?) with 1/4" hex shank. I have searched a lot for them and I could not see any. Knipex does this with 8 different heads, the triangle head in different sizes. I had a chat with a Knipex manager about making them with 1/4" hex shank explaining the reasons, but I think they have a lot of them in stock and they have to sell them first then they can go for a new design :))) The reason I want them to be with 1/4" hex shank is to be able to keep them organized in accessory cases, but a piece of metal like this with 4 or 8 heads is going to be at the bottom of the tool box and you will feel lazy to dig it out and you will use long nose pliers to open at the end. Next time when you see any box that needs this kind of keys check it carefully and you will see a sign of pliers being used in most cases. Also this happens because some guys who want to open these boxes do not have these keys as they are not so common. Have you seen triangle and square nut setters with 1/4" hex shank? Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 4 minutes ago, wingless said: Thanks for these, but zero use for the US. The taps available in the US have SAE fractional inch square drives, none have metric square drives. My current solution is using eight point sockets that fit my ¼" drive tools. I have not seen 8 point sockets at all, would you please provide any photo? Link? I have only seen 6 and 12. Quote Link to comment Share on other sites More sharing options...
wingless Posted April 10, 2022 Report Share Posted April 10, 2022 Here is a set. Mine is not a set, I have from small to large for square nuts, w/ ¼", 3/8" and ½" drive. 1 Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 2 minutes ago, wingless said: Here is a set. Thanks, Made in US Proto sockets. I would still like to have them as one piece with 1/4" hex shank. With these I need to use an adapter always. Plus if I need to keep them in DeWALT accessory cases I need to buy one adapter for each 1 Quote Link to comment Share on other sites More sharing options...
wingless Posted April 10, 2022 Report Share Posted April 10, 2022 3 minutes ago, Altan said: Thanks, Made in US Proto sockets. I would still like to have them as one piece with 1/4" hex shank. With these I need to use an adapter always. Plus if I need to keep them in DeWALT accessory cases I need to buy one adapter for each Agreed, SAE, fractional inch square socket ¼" hex shank bits would be handy for US taps. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 Here is the Knipex one Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 And this is the Wiha one, I could not find proper information bout the diameter of the part I have circled in yellow, if it is going to be thicker than 7mm it might be OK to CNC machine it. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 1 hour ago, wingless said: Here is a set. Mine is not a set, I have from small to large for square nuts, w/ ¼", 3/8" and ½" drive. I have found something for you! Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 I never thought I would find 4 point sockets. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 He has another nice video, very unique things you can see here. Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 SK PROFESSIONAL TOOLS Socket, 3/8 in Drive Size, 9/32 in Socket Size, 4-Point, Alloy Steel, Chrome Finish - 46C135|41439 - Grainger Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 Internal and external 4 point SK PROFESSIONAL TOOLS Socket Set, Socket Size Range 1/4 in to 3/8 in, Hand, Drive Size 3/8 in, SAE, 4-Point - 42W711|19781 - Grainger Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 1 hour ago, wingless said: Agreed, SAE, fractional inch square socket ¼" hex shank bits would be handy for US taps. You gave me an idea today and that was to look for triangle and square socket instead of nut setters with 1/4" hex shank and I found new things. Laser 5683 Triangular Socket Set 1/2"D 5pc : Amazon.co.uk: DIY & Tools Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 This is something strange also Sealey SX034 Strut Leg Pry Socket Set, 1/2" Square Drive, 2 Pieces : Amazon.co.uk: DIY & Tools Quote Link to comment Share on other sites More sharing options...
Altan Posted April 10, 2022 Author Report Share Posted April 10, 2022 The only problem is that they are with large diameter, and 1/2" square drive. CTA 1088 – 5 Pc. VW/Audi Triangle Bolt Socket Set 3 points femal sockets – Discount Warehouse Tools Quote Link to comment Share on other sites More sharing options...
