Dave S Posted May 18, 2022 Report Share Posted May 18, 2022 Is the a vendor that sells Ryobu 48v lawnmower battery recharger. QL-91435A-4801500H. I tried Ryobi and they do not have the part nor does the aftermarket seller they pushed me to. Mower works. Shame to toss it bc I cannot get a charge. Thanks Dave Quote Link to comment Share on other sites More sharing options...
jgilliam1955 Posted July 22, 2022 Report Share Posted July 22, 2022 Did you find a charger? Quote Link to comment Share on other sites More sharing options...
jamis Posted August 1, 2022 Report Share Posted August 1, 2022 It's a Delta Q SC-48 charger. It's supposedly custom set up to Ryobi's specs., but they are also used for golf carts. There were different Ryobi p/ns based on the mower's manufacturer number listed on the label under the seat. If you find a source, make sure the p/n matches the one on your original charger. Quote Link to comment Share on other sites More sharing options...
jamis Posted August 1, 2022 Report Share Posted August 1, 2022 Worst case, you could pull the battery tray per the manual instructions, disconnect the wiring, and charge each battery with a regular 12 volt battery charger, and then put it all back together. I can pull the battery tray in about 30 minutes. Quote Link to comment Share on other sites More sharing options...
jamis Posted August 1, 2022 Report Share Posted August 1, 2022 What's wrong with the charger? Is it showing any led indicators? Quote Link to comment Share on other sites More sharing options...
