Altan Posted April 30, 2023 Report Share Posted April 30, 2023 I saw it in Australian websites. Quote Link to comment Share on other sites More sharing options...
Jronman Posted May 3, 2023 Report Share Posted May 3, 2023 I have the old model. I wonder what is different about this model. Quote Link to comment Share on other sites More sharing options...
Altan Posted May 3, 2023 Author Report Share Posted May 3, 2023 10 hours ago, Jronman said: I have the old model. I wonder what is different about this model. The DCGG581 DeWALT 18V XR 2-Speed Grease Gun is perfect to use for a variety of lube maintenance applications ranging from Automotive, Factory, Heavy Equipment & Agricultural applications. These grease guns provide up to 10,000PSI Max Pressure and have a 1.2m long hose which provide greater accessibility around machinery. 10,000PSI Push Force - Max 10,000 PSI pressure to power through clogged grease fittings in speed one 2-Speed - Low 85g/min High 255g/min for increased versatility of application Ergonomic Grip Areas - Over-moulded & sculptured to fit the hand for optimum comfort & control Variable Speed Trigger - Add the precise amount of grease less waste Extra Long Grease Hose - 1.2m long reinforced hose for greater accessibility around machinery Bleeder Valve - Releases air in front of the grease tube makes it easy to prime pump when changing cartridges Bright Led - Illuminate work area for easier alignment of nozzle in hard to reach areas Cartridge Holder (ANZ 450G) - Screw top lid with that is easy to load with grease for greater user convenience Quote Link to comment Share on other sites More sharing options...
