kanxrus Posted September 21, 2013 Report Share Posted September 21, 2013 HERE IS ANOTHER LOOK INSIDE. 3 Quote Link to comment Share on other sites More sharing options...
bungee Posted September 22, 2013 Report Share Posted September 22, 2013 I take apart mine DCB204 - it was with green cells, but i am not sure about the model... Mine is from Home Depot, coming from Dewalt DCF895-M2 kit. What is the brand of the red cells? Quote Link to comment Share on other sites More sharing options...
tooldevil Posted September 22, 2013 Report Share Posted September 22, 2013 I take apart mine DCB204 - it was with green cells, but i am not sure about the model... Mine is from Home Depot, coming from Dewalt DCF895-M2 kit. What is the brand of the red cells? Hey Bungee, it looks like a Sanyo / Panasonic cell, if you google the No. that is printed on the cell, you will get a lot of information about the cell and the cell suppleir, I hope that helps Cheers Tooldevil Quote Link to comment Share on other sites More sharing options...
kanxrus Posted September 22, 2013 Author Report Share Posted September 22, 2013 These are the Sanyo cells. Interesting that you would find green (Sony cells) in a DCB204. I have yet to see a single Sony cell in the slide pack batteries. Quote Link to comment Share on other sites More sharing options...
bungee Posted November 13, 2013 Report Share Posted November 13, 2013 it looks more like https://www.google.bg/search?q=samsung+inr+20r&source=lnms&tbm=isch&sa=X&ei=Mf2CUue7McWGyQGb0IDwDg&sqi=2&ved=0CAcQ_AUoAQ&biw=1247&bih=677#facrc=_&imgdii=_&imgrc=9OhZmWXArJdlJM%3A%3BG8TC0OuIQdVySM%3Bhttp%253A%252F%252Fwww.akkula.fi%252FWebRoot%252Fvilkas02%252FShops%252F20110228-11092-27846-1%252F50DE%252F1D49%252FFF00%252FE06C%252FA90C%252F0A28%252F1005%252FE19F%252Fakkula_inr18650-20Ra.jpg%3Bhttp%253A%252F%252Fwww.akkula.fi%252FSamsung-ICR18650-20R-Li-Ion-battery%3B690%3B600 Quote Link to comment Share on other sites More sharing options...
bullethead Posted January 13, 2014 Report Share Posted January 13, 2014 my XR 20v tool has 4x terminals, 2 are negative & positive, the other 2 appear to be sensor wires (yellow/brown) (second from left & second right on battery top row) they go into the board (resin moulded) and back to the switch that powers the tool, what is sent from the battery via these two wires and how? I plan to run Lithium Polymer batteries (with built in protection) so need to supply the correct votlage/current to these wires so the tool will operate any help here greatly appreciated!! Quote Link to comment Share on other sites More sharing options...
simojoker Posted February 21, 2015 Report Share Posted February 21, 2015 I need the same information, have you find itmy XR 20v tool has 4x terminals, 2 are negative & positive, the other 2 appear to be sensor wires (yellow/brown) (second from left & second right on battery top row) they go into the board (resin moulded) and back to the switch that powers the tool, what is sent from the battery via these two wires and how? I plan to run Lithium Polymer batteries (with built in protection) so need to supply the correct votlage/current to these wires so the tool will operate any help here greatly appreciated!! Quote Link to comment Share on other sites More sharing options...
William S Posted August 2, 2015 Report Share Posted August 2, 2015 any reason you are going from ion to polymer? I mean what are the advantages you will gain from polymer over ion? Quote Link to comment Share on other sites More sharing options...
Bdwlf2 Posted June 9, 2016 Report Share Posted June 9, 2016 I was thinking about replacing the batteries with either LG-HG2 18650 batteries with a 20a discharge and 3000mAh capacity, or the Samsung 30Q 18650 batteries with basically the identical specs. (Samsung rates the 30Q as 15a, but testing shows that it handles 20a without breaking a sweat.) Anyone see any problems with doing this? This would make the DCB204 battery sled become a 6.0ah battery instead of the 4.0 stock. Also would give it a better discharge rate so the batteries won't overheat as quickly. Just asking if I'm correct in my assumptions and should carry-on with my battery upgrade. Any and all advice is welcome. Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted June 9, 2016 Report Share Posted June 9, 2016 Not sure how their electronics are with their batteries, I would just be careful, I'm not sure how they program their tools with overload protection. So swapping cells may not benefit at all if the chips limit it to the capacity of a 4.0 battery, it's a great question though I hope that it works. Jimbo Sent from my iPad using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
kdobrev Posted January 20, 2017 Report Share Posted January 20, 2017 Does somebody now know what each terminal of the battery is sending to the tool? Quote Link to comment Share on other sites More sharing options...
Cr8ondt Posted January 20, 2017 Report Share Posted January 20, 2017 2 hours ago, kdobrev said: Does somebody now know what each terminal of the battery is sending to the tool? b- and b+ are power, th and c3 are for the tools overheat sensor c1-4 are for balance charging and im not exactly sure what id is for Quote Link to comment Share on other sites More sharing options...
