stolis Posted March 1, 2014 Report Share Posted March 1, 2014 I recently bought the DCF895D2 impact driver witch comes with DCB101 charger...the problem is here in Europe I can't charge the batterie packs...will I be able to use the DCB105 to charge???The battery packs are DCB203... Quote Link to comment Share on other sites More sharing options...
DR99 Posted March 1, 2014 Report Share Posted March 1, 2014 It will work fine your just swapping chargers for one that runs on European voltage the battery pack does not care either way. Quote Link to comment Share on other sites More sharing options...
Gatorb888 Posted March 1, 2014 Report Share Posted March 1, 2014 I believe DR99 is right, US Batteries should work in EUR chargers and vise versa. Quote Link to comment Share on other sites More sharing options...
NicholasShetley Posted March 1, 2014 Report Share Posted March 1, 2014 The voltage coming into the charger shouldn't matter because it will have to drop to 18 volts. Quote Link to comment Share on other sites More sharing options...
stolis Posted March 1, 2014 Author Report Share Posted March 1, 2014 I believe DR99 is right, US Batteries should work in EUR chargers and vise versa. should work???what's the DR99 Quote Link to comment Share on other sites More sharing options...
stolis Posted March 1, 2014 Author Report Share Posted March 1, 2014 so using the DCB105 charger for DCB203 batteries will be safe and do its job right???is it for sure cause im about to buy one... Quote Link to comment Share on other sites More sharing options...
DR99 Posted March 1, 2014 Report Share Posted March 1, 2014 I'm DR99. The connectors and voltages are the same the packs are chargers are all interchangable all you need to worry about is the line voltage and connector for your country. Quote Link to comment Share on other sites More sharing options...
Javier Posted March 1, 2014 Report Share Posted March 1, 2014 You should listen to the DR it's good for you 1 Quote Link to comment Share on other sites More sharing options...
stolis Posted March 1, 2014 Author Report Share Posted March 1, 2014 Thank for the info and help.. Quote Link to comment Share on other sites More sharing options...
