40v Thoughts
Charles Harris
Having the 40v yard tools myself, I would hate any power tools that use the 40v platform. Those batteries are ridiculous in size and weight.
what about if they allowed a 9" grinder, large circ saw, plunge router etc?
I'm kind of in the mindset that not ALL tools need to be cordless. Granted, there is A LOT of wow factor and that's cool factor along with I want it because it's new, but I just don't see a huge need for them.
This sounds amazing. They absolutely should put heavy duty tools out with 40V. Cordless is the present and the future. Speaking as someone who spends most days on commercial construction sites, the less extension cords, the better.
I purchased the 40V blower and trimmer today. Those batteries are no joke. Maybe a table saw or 12" compound miter would work, but nothing handheld like a plunge router. I've heard people wish for a lawn mower but I just don't see the run time being available. A pruning chainsaw would be nice and complement the hedge trimmer, however.
Let us know what you think of them.
I'm a lot less inclined to buy the trimmer now. Just picked up a nice stihl fs80r for $100 this afternoon. It's one of the last 2 strokes stihl made without emissions.
Initial impressions were that the string trimmer does the job well. I was only trimming the fence lines so I didn't really have enough work to test out the run time. I also wasn't mowing down an overgrown lawn with it, which makes me wonder if the 20V application would be more suitable for me. I tried edging with it briefly and it did okay but an edging attachment or guide rail would have been nice.
The blower... I have several things to say about this one. First off, I've never owned a blower before and now can't understand why that was so! I do far prefer the style of the 20V blower to the centrifugal design of the 40V both for the aesthetics and the engineering. The 40V blower is just heavy enough that it's desirable to switch hands after a moderate amount of time, which places the air intake against your thigh. That being said, run time is an issue even with the 40V (4ah) that I can't see the 20V blower good for more than clearing off the driveway and shop floor. BTW, the property that I'm clearing is only about 10,000 sqft (~1/3 acre). I haven't quantified the actual run time that I'm getting from my 4ah batteries but I am a little dissappointed; I needed several batteries to finish blowing the back yard. I will probably return the 4ah model and order the 6ah. If only I had seen that extra battery rebate last month...!
The blower really is a great tool - I'm just nitpicking here. The balance is great and the volume of air is huge. Hopefully multiple 6ah batteries do the job.
Bummer about the 4.0's not having enough runtime for U Sarbatche that is a lot of property man compared to mine I think mines is about 5,000 sqft so they would probibly be good for my yard. I'm just waiting for my gas blower to take a dump b4 I go out and buy
Thanks for the info.
I have the ego blower now. My house sits on two lots. I have several huge white oak, hickory, sweetgum trees. The ego does a good job for smaller stuff but just doesn't seem to have enough power/runtime to blow the leaves. It does great for blowing the driveway off. I was hoping the DeWalt would be better, but I would probably be better off upgrading my gas blower to a backpack version and keeping the ego for smaller touch up jobs.
Update on the blower. I should have mentioned the condition of the lawn in my first post; It hasn't been raked or blown in at least a year and is surrounded by large white oak and sweet gum trees. The detritus on the ground was heavy, wet, rotting and choking out the grass. So this initial effort was definitely not just maintaining the lawn, hence the multiple batteries and multiple days required. I was also blowing the entire lawn from one end to another because there's a tree line at one end where I piled all of the leaves. It would have been much quicker if I had sectioned up the yard and created small piles to be bagged.
I had (2) 4ah batteries that I tested for run time over several days. The temperature was approximately 85 degrees F every day. The batteries were only used after the charger indicated a full charge. The blower was left running on max output from start to finish. Each battery on each day ran for 15:20-15:28 (mm:ss), which I consider to be a consistent result. This is the only blower that I've ever used so I don't know how 15 and a half minutes of run time suits people.
I've had the trimmer for a little over a month and have used the piss out of it. I got it at Lowes, so it's the 4ah. The rain we've been getting here in Tx has kept me busy, due to laziness and work getting in the way the back yard has been getting out of hand and the trimmer cuts through some serious weeds even with the .80 line. I'm still waiting on my extra battery. I'm confident that I can get through my back yard on one charge under normal use and usually even the front, but with all the rain I need a charge for the front and another on the back.  I seriously love it and will be getting the blower soon.
Only tools I could imagine are maybe a bigger miter saw or SDS.
  • 4 months later...
What about a hybrid tool? I would love to have a 40v 12" dual bevel sliding compund miter saw that could also be corded. That way you have the option of using battery power, if you are in an area where electricity is unavailible but also have the option of using mains power.
That's not a bad idea, or a table saw
Jimbo
From what I've been told 40v lawn mowers have more than adiquate power for small suburban lawns maybe 1/4 acre or so. Much more than that, you would need to go gas.
Not that I've tried it, but some whitepapers tests showed pretty close to petrol performance and high endurance with powerfull electric lawn movers like this: http://m.bosch-professional.com/gb/en/tools/cordless-tools/lawnmowers/gra-53.html?sPath=%2FdispatchToProductInCategory.html&defaultWebtrends=true&webtrends=Länderauswahl&webtrends=optional+Sprachauswahl
2x 36V,6Ah.
Would probably buy this compared to petrol. With an extra set of batteries, you could use it all day.
I wanna see a 40V demolition hammer. The 70 pounder!
After using the lawn equipment for sometime, I don't see the power to use the 40V in any construction tools. Just the blower alone, which the only resistance is AIR, doesn't run that long considering it's not cutting or breaking material.
    Swer15
    Swer15
