roadhog96 Posted June 13, 2015 Report Share Posted June 13, 2015 I'm trying to convince myself I need one but I honestly don't know if I really need it or just want the latest and greatest. Obvious things like sanding into corners, cutting nails flush, cutting into Sheetrock. What are some of the other things this tool would be good for? Quote Link to comment Share on other sites More sharing options...
Charles Harris Posted June 13, 2015 Report Share Posted June 13, 2015 Also add Scraping paint, wallpaper, etc. They also work great for cutting cardboard with a serrated knife blade. Quote Link to comment Share on other sites More sharing options...
ChrisK Posted June 13, 2015 Report Share Posted June 13, 2015 Plunge cutting into a solid material. I've plunged into solid hardwood floors, 2x4 material and trim boards to slide counters or whatever else you may have into. Making notches for mating pieces, sanding, rasping grout out between tiles.....I've got the Bosch MXH (Thanks Dan and Eric!). 18v cordless and very powerful brushless motor. Really handy tool to have. Quote Link to comment Share on other sites More sharing options...
Poisonfangs85 Posted June 13, 2015 Report Share Posted June 13, 2015 Finishing the cut in a corner so you don't have over cuts from a circular saw. Trim work, cabinets, hardwood flooring, I have even mortised doors for Locksets and hinges. Quote Link to comment Share on other sites More sharing options...
comp56 Posted June 13, 2015 Report Share Posted June 13, 2015 with a few different blades, the uses are endless.....it is not a tool I use everyday but it has saved the day many many times....I thought the same way as you did before I got mine ....and I'm sure glad I did...... Quote Link to comment Share on other sites More sharing options...
RickyMcGrath Posted June 13, 2015 Report Share Posted June 13, 2015 There are blades for pretty much anything you can think of. They may not be DeWalt blades, but with the dual attachment head, you can use any multi tool accessory ANYONE makes. I've used Bosch, Dremel, Rockwell and whatever else. Dremel makes razor knives for cutting carpet and other thin sheet goods. They also have a scroll saw style kit that has fine cable cutters for precision cutouts. If you get one, you'll be looking for reasons to use it. Quote Link to comment Share on other sites More sharing options...
Chris Posted June 18, 2015 Report Share Posted June 18, 2015 I do a lot of plunge cutting with mine. I would have to say it's become one of my most used tools while working on projects in my house. Quote Link to comment Share on other sites More sharing options...
PaulE Posted June 18, 2015 Report Share Posted June 18, 2015 i have a corded fein multimaster that i use often when installing cabinets. usually for plunge cutting holes for outlets. They are also great for cutting jams if you are installing flooring. They are handy, but most cutting applications you can use a jig saw or a sawzall. It is easier to control but tends to burn wood or mdf. Quote Link to comment Share on other sites More sharing options...
