Stercorarius Posted November 2, 2016 Report Share Posted November 2, 2016 Be a man get a Metabo Seriously though get the fuel Milwaukee. 2 Quote Link to comment Share on other sites More sharing options...
Jronman Posted November 2, 2016 Report Share Posted November 2, 2016 Might as well get the Powermatic PM2415B-3, 24" BANDSAW, 5HP 3PH 230/460V. A bit cumbersome to take to the jobsite but will cut through almost anything. A little expensive though. Quote Link to comment Share on other sites More sharing options...
Stercorarius Posted November 2, 2016 Report Share Posted November 2, 2016 1 hour ago, Jronman said: Might as well get the Powermatic PM2415B-3, 24" BANDSAW, 5HP 3PH 230/460V. A bit cumbersome to take to the jobsite but will cut through almost anything. A little expensive though. Personally this seems like the opposite of what I would want. To each his own though. First it's 230/460v which is three phase. Good luck finding that on a jobsite. Second it is stationary. No way anybody moves that after they install that. Much less brings it on a crawlspace. Handheld seems the only format a tradesmen would want. Third it's a woodworking saw. There is no way you would use that vertical style band on most metal applications. Fourth it's six thousand dollars. "might as well" buy a five tool fuel combo kit, fuel deep cut bandsaw, M12 bandsaw, M18 propress tool, M18 and M12 pex expanders and some other tools for not even close to that. 1 Quote Link to comment Share on other sites More sharing options...
lunicy Posted November 2, 2016 Report Share Posted November 2, 2016 I have both the corded one, and the cordless. (older, not the fuel m18) The cordless works just fine. I cut all types of angle iron, uni-strut, threaded rod, rebar. It does just fine. The corded one doesn't see the light of day anymore. 1 Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted November 3, 2016 Report Share Posted November 3, 2016 Yeah I need portability..... The fuel will ultimately be the one I get... probably! But it won't work for a lot of my applications tho honestly.... crawlspace or attic up against a joist etc... only a sawzall will work to cut out the old cast iron pipes. What a band saw will be good at tho is installing of punched angle iron and threaded rod etc, out in the open Quote Link to comment Share on other sites More sharing options...
Jronman Posted November 3, 2016 Report Share Posted November 3, 2016 20 hours ago, Stercorarius said: Personally this seems like the opposite of what I would want. To each his own though. First it's 230/460v which is three phase. Good luck finding that on a jobsite. Second it is stationary. No way anybody moves that after they install that. Much less brings it on a crawlspace. Handheld seems the only format a tradesmen would want. Third it's a woodworking saw. There is no way you would use that vertical style band on most metal applications. Fourth it's six thousand dollars. "might as well" buy a five tool fuel combo kit, fuel deep cut bandsaw, M12 bandsaw, M18 propress tool, M18 and M12 pex expanders and some other tools for not even close to that. I was trying to be funny. Quote Link to comment Share on other sites More sharing options...
Stercorarius Posted November 3, 2016 Report Share Posted November 3, 2016 8 minutes ago, Jronman said: I was trying to be funny. 1 Quote Link to comment Share on other sites More sharing options...
KnarlyCarl Posted November 4, 2016 Report Share Posted November 4, 2016 14 hours ago, Stercorarius said: Totally missed the sarcasm also..... @Jronman lol! Quote Link to comment Share on other sites More sharing options...
