Knipex flush cut pliars
SetBuilder
Yep it is. Are you looking for a larger set?
On 4/25/2017 at 10:23 PM, BMack37 said:
Yeah, most are 160mm to 125mm.
You can go through all their cutters on the left menu, the graphic you're looking for is KNPK1301_rot.gif
Looks like 72-01-180 is the largest
Currently these are my favorite pair of cutting pliers http://www.homedepot.com/p/Klein-Tools-8-in-Diagonal-Cutting-Pliers-D2488/100648071
I'm looking for flush cut pliers that could easily cut 16 gauge staples.
8 hours ago, KC_Tool said:
I wouldn't cut metal with those. They are designed for plastics. I might suggest
74-01-180 even though they cut with a bevelled edge.
Agreed, the truly flush cut is mostly for plastics and leads(on a capacitor or resistor), I don't even use them on diodes. The Kleins are also double beveled, the Knipex should be a great replacement. I've cut (small) screws and nails with my 7" Knipex diagonal cutters.
    Dmiller
    Dmiller
