grthebigg Posted November 18, 2020 Report Posted November 18, 2020 i want to buy a cutting plier , but i need your help. i want to cut maximum 1.5 mm pure copper wire for making chains and inside ring minimum diameter is 2 mm. see the photo: i mean one of The tip of the plier jaw can be inserted into the ring easily and cut the wire nicely without problem. Can you introduce me to some models? thank you
Eric - TIA Posted November 19, 2020 Report Posted November 19, 2020 Great question. I am not sure which pair has a small tip to fit inside that ring. I would check Klein and Southwire. If they don't have it, I am sure there is specialty jewelry cutters but not familiar with that market.
wingless Posted July 31, 2021 Report Posted July 31, 2021 Why not instead use a rotating cutting wheel disc, maybe a Dremel?
micrx145 Posted August 14, 2021 Report Posted August 14, 2021 I cut them with custom-made pliers, because almost buying modern things never work for me, I end up breaking them down and spending more.
