Jronman Posted August 22, 2021 Report Share Posted August 22, 2021 DeWALT is releasing a new Impact driver with essentially the same specs as the 887. According to the specs sticker on the tool, it has a bit more ipm but otherwise the same specs. The biggest difference is the size. The tool is now 4 inches from back to front. So small that the battery sticks out farther than the chuck. Shortest impact that I know of. In my search I found no impact that was as short as the DeWALT. The tool has xr branding but apparently it is an atomic tool. The picture shows no Atomic branding. It was pictures of a European model which might have different branding than North America. Travis from Tools by design made a post about it.https://www.instagram.com/p/CSzaFkxnWVw/ 1 Quote Link to comment Share on other sites More sharing options...
wingless Posted August 23, 2021 Report Share Posted August 23, 2021 Cool. Thanks for sharing. Click save and a side by each of new DCF850 to a DCF887. FWIW, here is my DCF887 topic. Eyeball measurement looks identical dimension from trigger face to rear surface. Everything else got smaller. The gear box behind the chuck is smaller and the motor is smaller. Interesting that there is now a couple degree head tilt, likely so the battery doesn't prevent the head from reaching the work surface. Nice job DeWALT! 1 Quote Link to comment Share on other sites More sharing options...
fm2176 Posted August 23, 2021 Report Share Posted August 23, 2021 Looks nice, definitely shorter than the 887! Quote Link to comment Share on other sites More sharing options...
aabee Posted August 28, 2021 Report Share Posted August 28, 2021 Looks nice, if borderline comical. Makes me wonder about the usefulness of the Xtreme line moving forward if this is possible. Quote Link to comment Share on other sites More sharing options...
Jronman Posted August 29, 2021 Author Report Share Posted August 29, 2021 No other regular impact driver is shorter than this. you would have to move into right angle impacts. 1 Quote Link to comment Share on other sites More sharing options...
