Shug Posted August 1, 2022 Report Share Posted August 1, 2022 I like this tool up to when I was using it in heavy weeds and it bogged down and stopped, I cleared the weeds from the head of the trimmer that were causing the issue and it restarted. Then it stopped again same reason, cleared the weeds wrapped around the head then tried to start it, pulling the trigger resulted in the head clicking and slowly moving a small amount, tried again same thing happened. Changed the battery same thing. Removed the head, cleared a very small amount of dried grass from the dismantled head, re assembled and tried to start, no change it wouldn't start. Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
RDC Posted October 15, 2022 Report Share Posted October 15, 2022 If you pull the trigger and only get a tiny 'bump' from the motor, that's a pretty classic symptom of the motor driver board being bad. That can also show up as nothing happening when pulling the trigger. I'd pretty much guarantee you it has some bad MOSFETs on the thing now, as I just tore one of those down here looking for that exact problem. It'll probably come as no surprise that none of that stuff is even remotely easy to replace. Even if you can get parts, you'd have to replace the entire field/driver assembly of the motor to avoild any soldering or real PITA PCB de-potting, unless you're far enough off your meds and rocker to replace the FETs like I'll be doing to this one. 1 Quote Link to comment Share on other sites More sharing options...
RDC Posted October 30, 2022 Report Share Posted October 30, 2022 OK, replaced the FETs (only the one damaged pair as the other 2 pair were still good) and replaced the 2 Capacitors that are missing in the last posts image, and she was still a dead duck. So I dug a little deeper and found an open Resistor in there as well, one of the 53B, 3.48k. Replaced that and she took right off. After I pull the PCB back off one last time to clean it up and recoat it then she'll be ready to wack some more weeds. Quote Link to comment Share on other sites More sharing options...
Eric - TIA Posted October 31, 2022 Report Share Posted October 31, 2022 Sweet. Nice to be able to fix it on your own. Quote Link to comment Share on other sites More sharing options...
RDC Posted November 15, 2022 Report Share Posted November 15, 2022 Ran across another one of these that was supposedly 'dead', but after tossing a battery in there the thing technically worked. The motor sounded horrible and it had more grass in it than it probably ever cut, but the top motor bearing was shot, which was making all the noise. Fun part about this one, the marking on the top bearing was 695Z, but the 695Z bearing is 5 x 13 x 4mm, and the one in this thing is 5 x 16 x 4mm. So I had to toss a 625Z in there instead, which is 5 x 16 x 5mm, just 1mm wider, but there is plenty of room for that in there and now this one is good to go again. 1 Quote Link to comment Share on other sites More sharing options...
Tom W Posted December 12, 2023 Report Share Posted December 12, 2023 On 11/15/2022 at 5:38 PM, RDC said: Ran across another one of these that was supposedly 'dead', but after tossing a battery in there the thing technically worked. The motor sounded horrible and it had more grass in it than it probably ever cut, but the top motor bearing was shot, which was making all the noise. Fun part about this one, the marking on the top bearing was 695Z, but the 695Z bearing is 5 x 13 x 4mm, and the one in this thing is 5 x 16 x 4mm. So I had to toss a 625Z in there instead, which is 5 x 16 x 5mm, just 1mm wider, but there is plenty of room for that in there and now this one is good to go again. How did you get the black sealant off? Also what did you use to seal the board up again? Thanks. Quote Link to comment Share on other sites More sharing options...
sawihel Posted February 18 Report Share Posted February 18 On 8/1/2022 at 6:03 AM, Shug said: Right in the middle of using it. I’ve used it lightly for about 13 months. It jammed up and would just “click” while other times it would turn “gravely” I took it apart thinking something broke or was getting jammed in the reduction gear. Nope… gears were fine. It was the motor. Black gritty magnet bits stuck to the outer magnets. I’d guess they are inside also causing the intermittent locking or grave feeling. Now, what to do? Test the Dewalt 3 year limited warranty or just buy a new bare tool for $99… (or both) Quote Link to comment Share on other sites More sharing options...
Tom W Posted March 11 Report Share Posted March 11 On 2/18/2024 at 5:39 PM, sawihel said: Right in the middle of using it. I’ve used it lightly for about 13 months. It jammed up and would just “click” while other times it would turn “gravely” I took it apart thinking something broke or was getting jammed in the reduction gear. Nope… gears were fine. It was the motor. Black gritty magnet bits stuck to the outer magnets. I’d guess they are inside also causing the intermittent locking or grave feeling. Now, what to do? Test the Dewalt 3 year limited warranty or just buy a new bare tool for $99… (or both) Try the warranty first. Quote Link to comment Share on other sites More sharing options...
TylerDFW Posted May 8 Report Share Posted May 8 On 11/15/2022 at 4:38 PM, RDC said: So I had to toss a 625Z in there instead, which is 5 x 16 x 5mm, just 1mm wider, but there is plenty of room I’m replacing a top bearing and there seems to be a red rubber stopper thing maybe in the way. How do in navigate this? update: just pull out the gear and rotor, shake clean, swap bearing, and bolt it back together. Super easy 10 minute fix. Don’t worry about the red rubber thingie. Quote Link to comment Share on other sites More sharing options...
Anowar Posted June 9 Report Share Posted June 9 Here are some steps you can take to troubleshoot the issue: Basic Checks: Battery: Make sure the battery is fully charged and securely connected. Try using a different Dewalt 20v battery if available to see if the issue persists. Power Switch: Ensure the power switch is turned on completely. String Trimmer Head: Check if the trimmer head is jammed with debris or tangled string. Clear any obstructions and ensure the string is properly fed according to the trimmer manual. Further Troubleshooting: Overheating: String trimmers can overheat, especially under heavy use. Let the trimmer cool down for 15-20 minutes before attempting to restart it. Debris Buildup: Clean any dust and debris buildup around the motor vents. You can use a compressed air can for this purpose. Manual and Online Resources: Consult the Dewalt DCST922 user manual for troubleshooting tips specific to your model. You can also search online forums or [YouTube videos](search for "Dewalt DCST922 string trimmer fix") for solutions from other users. Quote Link to comment Share on other sites More sharing options...
