Epoxy and Wood Serving Tray
Jronman
I built this epoxy and wood serving tray for my sister as a Christmas gift. It was the first time I have ever done anything with decorative epoxy. I used Mahogany for the wood. The green river and dark grey  L and circle were cut out with my Shaper Origin cnc. The epoxy had Black Diamond Pigments mixed in for the colors. For the epoxy I used Total Boat brand table top epoxy. I realized that was a mistake in the sense it could only do 1/4 inch thick pours at one time so i had to do multiple pours which resulted in more work because I could not pour in one shot. I decided once I finish what I have, I will be switching to Black Forest Wood Co deep epoxy. I expect to get one more board out of what I currently have before I need to order more epoxy. Took about 1/2 US gallon of epoxy for this pour and I had a one gallon kit. The finish I used was also from Black Forest Wood Co. I did two coats of their furniture oil. It was the first time I used my Rotex for applying finish. The Rotex worked great. When the oil was cured I put on their diamond level furniture ceramic product. It is a two part product. I did a coat of the diamond base coat then I did a coat of their top coat.  I want to say I had an estimated 20 hours spent on the board not including the dry time for epoxy and finishes. I think I could get it down to almost half of that if I can pour the green section in one shot, get the cnc time cut down and optimize some of the other tasks.
Wow that is such a nice job, came out awesome.  The first time is always more than what you think.  I poured Ardex in my mudroom thinking it would be a simple process.  Would have been simple if I read the directions, but didn't.  In the end, I had to do 4 pours when I could have done one pour.  Oh Well.
Should take me less time next time I do it.
