mgriggle Posted December 28, 2012 Report Share Posted December 28, 2012 Can a Lithium Ion dw9141 14.4 battery be used to replace a DW9094 Ni-Cad used in older XRP? Quote Link to comment Share on other sites More sharing options...
kjones Posted December 29, 2012 Report Share Posted December 29, 2012 Yes,but you will need a dual chemistry charger as well. Quote Link to comment Share on other sites More sharing options...
mgriggle Posted December 30, 2012 Author Report Share Posted December 30, 2012 The Lithium battery has two full height lugs and two half height lugs on the outside of the rectangular connector which prevent inserting in the XRP. Do I/can I remove these off to make it fit? Quote Link to comment Share on other sites More sharing options...
kjones Posted December 30, 2012 Report Share Posted December 30, 2012 No. Those are there to prevent you from accidentally plugging the li-on batteries not a NiCAD charger. The charger will not recognize the chemistry, and will charge it wrong (ruining the battery, or possibly causing fire, etc.). If you want a lithium battery, you need the lithium charger. The lithium charger recognizes both chemistries, so it will charge all of your DeWALT stem pack batteries. Quote Link to comment Share on other sites More sharing options...
