Skylar87 Posted April 27, 2014 Report Share Posted April 27, 2014 This is my home made forge. 6 stainless rings welded together then cut into four long peices. An welded to a 12"x12" stainless plate and welded corners in. then weled 7 3"rings toegther and weld it to the bottom for that dics brake. An i welded a pipe with the same dim. of the hair dryerin the side to finish off the top half. Then cut a cycle hole to match the inside dim. of a disc break. An welded cast iron to stainless steel. the bottom half is a disc brake welded to a 4" pipe with a slot cut out for the pipe with the hair dryer on it. Quote Link to comment Share on other sites More sharing options...
DR99 Posted April 27, 2014 Report Share Posted April 27, 2014 That's pretty darn cool. I don't know what I would end up using a forge for myself, but that's pretty awesome being home made! What are you making with the forge? Quote Link to comment Share on other sites More sharing options...
Conductor562 Posted April 29, 2014 Report Share Posted April 29, 2014 That is pretty sweet. I'm looking forward to the answers as well. Quote Link to comment Share on other sites More sharing options...
regopit Posted April 29, 2014 Report Share Posted April 29, 2014 That is pretty cool Quote Link to comment Share on other sites More sharing options...
Skylar87 Posted May 1, 2014 Author Report Share Posted May 1, 2014 Sorry it has took so long to answer DR99 but I have made 12" blade machete and 3/8" thick and 5 knifes and I hardened and tempered them too. An I made custom bent brackets for two hand rails. I built ithe forge to see how tools and weapons were made a long time along before there were mechines to do the work. An how much time is invested to make just one tool. Quote Link to comment Share on other sites More sharing options...
