mws_1984 Posted August 5, 2015 Report Share Posted August 5, 2015 So I was helping work on a buddies race car and they realized they had forgotten the cordless impact gun. Well I always bring my tools in my car just in case. Well this was the first time using it and I found it seemed to struggled to pull the lugs off. They had been torqued but it was a bit unnerving that it was struggling to do so. I think this gun has 1740 lbs of torque. I'm not sure what the lugs had been torqued at with the torque wrench. But any reason why they weren't coming off as fast as they should have been. It almost had to get a bite to get them going. Had to use the socket to loosen them by hand then use the gun. We have a bigger version of same gun. Mine juast happens to be the compact version. Quote Link to comment Share on other sites More sharing options...
jeffmcmillan Posted August 5, 2015 Report Share Posted August 5, 2015 Usually impact wrenches are rated in ft-lbs and 1740in-lbs converts to 145ft-lbs which is not that much. If the lugnuts were over-tightened a bit or the required torque was higher than the average car (I don't know much about race cars) it could easily have trouble with the lugs. Quote Link to comment Share on other sites More sharing options...
DR99 Posted August 5, 2015 Report Share Posted August 5, 2015 Your impact wrench is based off the impact driver platform. You need the bigger gun for the high torque applications. Even then the old Dewalt 18v guns and weak compared to the new 20v Brushless version. Heck even the first 20v max versions were not that impressive. Quote Link to comment Share on other sites More sharing options...
mws_1984 Posted August 11, 2015 Author Report Share Posted August 11, 2015 I know the usual gun they have is a DW059 and it's listed as Heavy Duty. It is bigger than my compact version. So maybe mine is just slightly less powerful. Plus I have no idea what the lugs were torqued at so that could be an issue to. Just torque them til it clicks normally with no idea what it is set at. Never had anything come off so must be good enough. My gun is good just in case. Even if ya gotta loosen them by hand to start. Quote Link to comment Share on other sites More sharing options...
