Trim guy Posted December 3, 2015 Report Posted December 3, 2015 For those who use their Dewalt multi tools for sanding, where do you find sand paper? I like 120-150 grit. I've ordered Dewalts DWASPTRI123. But they are quite a bit small for Dewalts sanding pad. So I'm using them with the corded Fein that has a smaller sanding pad
comp56 Posted December 3, 2015 Report Posted December 3, 2015 is it hook and loop? if so just buy ones that fit better size wise....
Trim guy Posted December 3, 2015 Author Report Posted December 3, 2015 I am having a hard time finding "better / perfect fit size wise"
Turner85 Posted December 3, 2015 Report Posted December 3, 2015 For those who use their Dewalt multi tools for sanding, where do you find sand paper? I like 120-150 grit. I've ordered Dewalts DWASPTRI123. But they are quite a bit small for Dewalts sanding pad. So I'm using them with the corded Fein that has a smaller sanding pad In europe I order from multitoolworld, probably of no help to guys in the U.S
Mr. Yellow Posted December 3, 2015 Report Posted December 3, 2015 I find the sanding accessory a crappy piece of plastic. Maybe I am using it wrong, but when I use it on detailing the velcro burns up in one corner making the sanding pad come off. Maybe I'm pushing too hard, but I burned up 2 of those in a relative short period of time.
Turner85 Posted December 3, 2015 Report Posted December 3, 2015 I find the sanding accessory a crappy piece of plastic. Maybe I am using it wrong, but when I use it on detailing the velcro burns up in one corner making the sanding pad come off. Maybe I'm pushing too hard, but I burned up 2 of those in a relative short period of time.Your not alone there
LR714 Posted December 4, 2015 Report Posted December 4, 2015 Take a look at this: http://multifitblades.com/small-project-sanding-kit.html
Kenneth Denmark Posted December 4, 2015 Report Posted December 4, 2015 I find the sanding accessory a crappy piece of plastic. Maybe I am using it wrong, but when I use it on detailing the velcro burns up in one corner making the sanding pad come off. Maybe I'm pushing too hard, but I burned up 2 of those in a relative short period of time.You push to hard.. Let the machine do the work.. ;-) 1
mohawkdec Posted December 5, 2015 Report Posted December 5, 2015 my multi tool gets used more for sanding than anything else as we do alot of custom work. i buy the paper at my local curtis lumber store. lowes carries the smaller size but you will have to buy the smaller rockwell pads also. they fit just like the dewalt pads. i go thru alot of pads, i found that if you use it at a slower speed the pads will last longer, i also keep rotating the pad, the dewalt quick release makes this simple.
