comp56 Posted January 12, 2016 Report Share Posted January 12, 2016 ok so without looking to hard.....I couldn't find a Betterley zero clearance insert for my new miter saw so of course I made one......I did it the same way as the fence all in reverse so it does not wear off the name.....made the insert and fit it first.....drilled the holes to match then cut it out with blade to give it the zero clearance.....after adding my little betterley touch this is what it looks like.....other things are I retrofit the rectangular dust port to fit my 4" hose for dust collection so it is ready for work..... 2 Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted January 12, 2016 Report Share Posted January 12, 2016 Impressive as always compSent from my LG-V410 using TapatalkJimbo Quote Link to comment Share on other sites More sharing options...
unclebud Posted January 12, 2016 Report Share Posted January 12, 2016 Very professional looking comp. Quote Link to comment Share on other sites More sharing options...
ChrisK Posted January 12, 2016 Report Share Posted January 12, 2016 Comp great job as always, what kind of laminate did you use? Why did you put betterley on it and not your name? That thing is classy dude!!! You gotsta represent the Comp! Quote Link to comment Share on other sites More sharing options...
comp56 Posted January 12, 2016 Author Report Share Posted January 12, 2016 lol cause I'm not a smart guy and didn't think of putting my own name on it...lol might now though thanks for the tip....lol Quote Link to comment Share on other sites More sharing options...
Bigmikez Posted January 12, 2016 Report Share Posted January 12, 2016 Amazing work Comp! Quote Link to comment Share on other sites More sharing options...
ChrisK Posted January 12, 2016 Report Share Posted January 12, 2016 Well Comp....I'm thinking you should post that pic to betterley and get a royalty!! 1 Quote Link to comment Share on other sites More sharing options...
khariV Posted January 12, 2016 Report Share Posted January 12, 2016 Looks great. The stock plates don't quite close enough for a 90 degree bevel, so this will no doubt be quite the improvement. Now if only there were a quick change mechanism so you could swap out for a bevel zero clearance set on demand you'd be all set. I sense another project in the offing...Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
