Kreg clamps
SetBuilder
I have one, tbh it sucks as locking pliers but because it fits the kreg jig, I use it a lot. It's like any other cheap locking pliers with a soft grip (That slips), I'm used to Knipex and Grip On locking pliers so...yeah.
They were on sale some time ago on Amazon and I think Lowe's has them for $25. If you use the Kreg jig a lot, then get it.
Thoughts @JimboS1ice?
I have a k4 kreg jig. I dont use it to hold the jig down but I use them to hold pieces flush with each other. That is where they really shine. They have a wide surface to get both pieces of the boards at once and allows for the connection to be flush. The automax clamps are far superior to the regular kreg clamps. I have the deep 6" ones and use them often.
I went to Lowe's on this recommendation, Rich is dead on...the Automaxx clamps are about 30% more in price but easily 300% better clamps. I will be getting some of those clamps.
6 hours ago, FrosBros82 said:
@BMack37, are they a flat face? Also, is it something you can use on wood? Or will it mark it up?
They have a rotating flat plate that won't mark wood unless you really crank it down.  I use them on pine all the time without marking.
Exact same face as the regular clamps. It has a better and larger grip, it has a nice screw adjust that can REALLY adjust a wide variety of tightness-es. It looks and feels much stronger than the regular clamp. Night and day difference, everything I hated about the regular clamp is fixed in this clamp.
I realize I'm late to the party, but I've got the automax and use them all the time. A little herky jerky to release sometimes, but they're super quick to use and give a pretty good hold. I use them to hold boards on the drill press or for routing mostly.
BTW, on instagram a person I follow was talking up Armor tool clamps and I noticed they look exactly like the Kreg Automaxx clamps, I asked and they are indeed the OEM of the Kreg clamps. https://www.armor-tool.com/
Pricing is about the same but it's an alternate retailer for them and they should have more available products.
I saw those posts too and wondered if they were a copy or from the same place. thanks for checking.
    tharunjohar46
    tharunjohar46
