18V-20V BATTERY ADAPTER DCA1820
Hornnumb2
I want to say it works with 2.0 ah or under batteries... Might be some users that said the 3.0 or 4.0 packs work too but definitely the kit ships with 2.0s, voltage wise there is no change what so ever, "20v" Dewalt batteries are really just 18v. Lithium cells don't have memory drain and don't fade in power like NiCad cells do, it's a much better battery composition and you can achieve higher amp draw with lithium packs, which was speculated to be an issue with higher ah packs on the older xrp tools
Jimbo
    Ren
    Ren
