farrero Posted August 20, 2009 Report Share Posted August 20, 2009 ALL CUTS ARE WRONG JUST BOUGHT IT FROM INTERNET. BLADE NOT CUTTING SQUARE AND THE DETENT SHOWS 2 DEGREES OUT LEFT AND RIGHT ANY HELP WILL BE MUCH APPRECIATED. THE MODEL IS DW717XPS-GB. CAN SOMEONE POST A PICTURE TUTORIAL CHEERS Quote Link to comment Share on other sites More sharing options...
kanxrus Posted August 20, 2009 Report Share Posted August 20, 2009 Loosen up the Detent plate screws, get a right angle square and square the table back up and tighten the screws back down. Quote Link to comment Share on other sites More sharing options...
irishroey Posted October 21, 2012 Report Share Posted October 21, 2012 Hi my mitre saw dw718 is cutting off square also but its on the tilt arm it's ok at 45 or 22.5 its just at zero I need to square it up and tighten the handle but it can get annoying and time consuming after a few cuts having to this Any help would be great Quote Link to comment Share on other sites More sharing options...
Mr. Yellow Posted October 22, 2012 Report Share Posted October 22, 2012 The easiest way is to read the manual in this case. It provides all the steps to (re)align your saw, both miter and bevel. See here http://servicenet.dewalt.com/Products/Detail/DW718#, download the manual and look for page 7 Quote Link to comment Share on other sites More sharing options...
irishroey Posted October 26, 2012 Report Share Posted October 26, 2012 Cheers mr yellow Ill read that an see how I get on thanks Quote Link to comment Share on other sites More sharing options...
richo1234 Posted September 23, 2014 Report Share Posted September 23, 2014 this is not uncommon on all saws.download the manual and most explain how to adjust .A large builders square is really handy for this and dont loosen the bolts to much,It will take some patiance .good luck Quote Link to comment Share on other sites More sharing options...
chadlanthier Posted September 26, 2014 Report Share Posted September 26, 2014 When ever I need help, I turn to YouTube, there's a video out there for almost any problem. Quote Link to comment Share on other sites More sharing options...
comp56 Posted October 3, 2014 Report Share Posted October 3, 2014 never go by the numbers you see always go by the square, these things are mass produced and some times the indicator can be off by a step or so or even the indicator needle can be off..........any brand any model...... the ol saying measure twice cut once same as with a mitre saw check before cutting 54 wrong angles Quote Link to comment Share on other sites More sharing options...
chadlanthier Posted October 26, 2014 Report Share Posted October 26, 2014 Yep building a deck this summer, moved my miter saw around a few times and did not notice right away that the angle adjustment had moved. I was like what the hell. Quote Link to comment Share on other sites More sharing options...
