kanxrus Posted April 19, 2011 Report Share Posted April 19, 2011 RYOBI 24V LITHIUM ION BATTERY OP241A SANYO UR18650SA P0S4 Specs Quote Link to comment Share on other sites More sharing options...
framer Posted April 19, 2011 Report Share Posted April 19, 2011 are those good battery cells? Quote Link to comment Share on other sites More sharing options...
kanxrus Posted April 19, 2011 Author Report Share Posted April 19, 2011 I think they are currently Sanyo's lowest capacity battery in the 18mm x 65mm series. Quote Link to comment Share on other sites More sharing options...
Madtec Posted April 21, 2011 Report Share Posted April 21, 2011 I think they are 1.3Ah cells Quote Link to comment Share on other sites More sharing options...
Hawkfan23 Posted April 22, 2011 Report Share Posted April 22, 2011 Aren't the cells in the 12v max batteries sanyo's as well? Quote Link to comment Share on other sites More sharing options...
ToolGeek Posted April 22, 2011 Report Share Posted April 22, 2011 Sanyo ma kes a lot of different cells. Ryobi is using the bottom of the barrell Dewalt is at the top of the barrel. Quote Link to comment Share on other sites More sharing options...
Madtec Posted April 23, 2011 Report Share Posted April 23, 2011 I think they are 1.3Ah cells The 12v is using the SAX cell, the SA which is used in the ryobi is a little under-performing Quote Link to comment Share on other sites More sharing options...
kanxrus Posted April 23, 2011 Author Report Share Posted April 23, 2011 Just to re-clarify. Sanyo makes many cells, this way you can pick and choose which cell works best for your application, and cost control. Ryobi being a consumer tool, felt it un-necessary to use a higher grade cell.... most likely because of cost. Quote Link to comment Share on other sites More sharing options...
