toolsinaction Posted January 3, 2014 Report Posted January 3, 2014 Hi everyone, we are working on updating the forum. Hopefully you will enjoy the new changes. Post any issues here.
toolsinaction Posted January 3, 2014 Author Report Posted January 3, 2014 We are working on the look :}
Gatorb8881393434512 Posted January 3, 2014 Report Posted January 3, 2014 Needs more yellow Say's Mr. Yellow, haha Looks great, I'm excited about the new look! 1
Brien Posted April 7, 2014 Report Posted April 7, 2014 I turn my head for one second and this is what you do to my Forum! I fear change. I still run 18V nicad dewalt batteries, I still have a flip phone, my car has a cassette player and Miami Vice is my new favorite show. 5
Nordraw Posted January 7, 2015 Report Posted January 7, 2015 Change can be a good thing. Only time will tell as always huh? Looks good.
NERemodeling Posted January 7, 2015 Report Posted January 7, 2015 looking forward to the changes! not sure if its me doing something wrong but when i click on a topic on the full site version it always takes me to the first origional post in that thread.. on the mobile version it remembers the last post i read and brings me to the most recent post that i havent read.. this isnt a new problem just something that has always been since i started here.. a minor fustration. is it me or is that the way the full version works?if thats the way it is, is there anyway to make it act like the mobile version? let me know if i wasn't clear, ill try to re-explain Thanks guys, keep up the good work! TIA kicks ass
NERemodeling Posted January 7, 2015 Report Posted January 7, 2015 hey, for the first time ever i just hit a limit of "likes" per day is that a new change or something that has always existed? what is the limit?
Bigmikez Posted January 7, 2015 Report Posted January 7, 2015 cant wait to see the new changes very exciting!!! T.I.A!!
chadlanthier Posted January 7, 2015 Report Posted January 7, 2015 I can't wait to see what's in store. Brien you r hysterical. As far as problems, pictures, not enough yellow, I think new registers 1st post should be introduce yourself, I have to post a post- then edit in order to get emoticons to show up on post. Also if not the one creating a post, I have to post then edit to add photos, post counter.
chadlanthier Posted January 7, 2015 Report Posted January 7, 2015 Oh and giveaway winners should be up near top next, UTB giveaway.
ChrisK Posted January 8, 2015 Report Posted January 8, 2015 More....MORE....Yellow?!?!?!?!?!!? How's about some Blue and Green? How's about some Blue and Red? My God in Heaven!!! I know I just added a bunch of yellow to my shop but cmon!!!! Give an under cover brother a break!!!!
chadlanthier Posted January 8, 2015 Report Posted January 8, 2015 In all seriousness, I think we are going to have a lot of yellow coming out from dewalt. Dan and Eric r going to be very busy.
madman_us Posted January 8, 2015 Report Posted January 8, 2015 changes? oh sweet - cant wait to see them.how about a Bosch Main Thread; I would hang out there all the time and keep posting stuff
chadlanthier Posted January 8, 2015 Report Posted January 8, 2015 Madman we didn't realize u like Bosch. Maybe we can get u some help.
WillyG Posted February 18, 2015 Report Posted February 18, 2015 HI, This is my first post and I hope someone can help. I'm repairing a dewalt framing nailer, #d15844. The tool started to blow air out the front and quit driving nails. I ordered an o-ring kit and installed the new o-rings. The kit did not contain o-rings for the trigger assy., but after inspecting the assy., the o-rings looked good, as did the plastic assy. No cracks noticeable, and I reinstalled. After assembling the tool, and applying air pressure, all air leaks were repaired, but tool still will not drive a nail. Tool gives a "puff" type sound and seems to be moving the hammer, but not enough to even start to drive a nail. Now, I'm suspect of the trigger assy. It seems to not be moving as freely as it should, but will cause the tool to fire. Also, after removing the "exaust assy" from the rear of the tool and applying air pressure, air is excaping out the inside on the handle. Is this normal, or is the trigger assy not working correctly? This trigger assy cost around 40 bucks and I don't want to spend money on a part that is still good. I hope I have explained the problem clear enough so someone will have an idea how to fix this tool. Any help will really be appreciated. Thanks, WillyG
NERemodeling Posted February 19, 2015 Report Posted February 19, 2015 Hey Willy. While I'm not familiar with that particular gun I have rebuilt several framing and roofing guns over the years any typically the o-ring kit solves the problem.. are you position very everything going went back in the correct order?Also is it cold out where you are? Nail guns don't like to work when it's cold out.. leave the gun inside overnight somewhere near a head source and check it again the next day.. did you verify that there is no issues with your air hose and that your compressor is supplying somewhere around 100psi??
WillyG Posted February 19, 2015 Report Posted February 19, 2015 Hey John: Thanks for the reply. The air compressor is putting out about 120 lbs. And yes, its really cold down here in Hartwell Ga. Around 18 degrees today, but thats not normal for here. Would you know if the trigger assy. is susposed to cut off all air to the gun, in the neutral position. Now, the gun is passing a considerable amount of air passed the trigger assy. This does not seem normal to me. To me, at least 1/2 the air pressure is being used up before the trigger is pulled, whice does not leave enough air pressure to fire the driver. What do you think?
NERemodeling Posted February 19, 2015 Report Posted February 19, 2015 Its hard to say exactly.. 18 degrees is definetly cold enough to start making a gun act up, when they are cold they tend to leak air and not fire.. my guess is that the o-rings inside contract due to the cold and let air leak past (just my own hypothesis though) due to cold, i have had guns that just continuously leak air when they are plugged in and also ones that make a air leak noise only when you attempt to fire a nail.. i would say before you do anything else to the gun let it get good and warm inside and then test it .. hopefully its as simple as that, if not then the trigger valve seems like the next reasonable guess. good luck! whenever im framing or roofing in freezing temps i always leave my guns inside overnight and bring them in durring breaks and lunch that seems to help for me
madman_us Posted February 19, 2015 Report Posted February 19, 2015 Madman we didn't realize u like Bosch. Maybe we can get u some help.help? nobody can help someone who is infected with the TIA disease - specially with this crew who talks you into new tools
NERemodeling Posted February 19, 2015 Report Posted February 19, 2015 Madman, nobody has to convince you of buying new tools!! you do a damn good job of convincing yourself
madman_us Posted February 19, 2015 Report Posted February 19, 2015 ppsssshhhhh i try to point fingers at the others that i dont have to feel "so" bad lol
NERemodeling Posted February 19, 2015 Report Posted February 19, 2015 ahhhhhh i get it glad to be your scapegoat
