Complete Basement Project
Brien
Since this is my 100th post I thought I would commemorate the moment with some pictures of a basement project that I am wrapping up.
I am a one man show with the exception of a very talented painter/drywall guy.
This project kept me busy for just over a year. I have a full time job during the day… so I worked this one on weekends and the occasional weeknight…  call it moonlighting, burning the candle at both ends, whatever but I like using tools...
Here are a couple shots during the framing and electrical rough-in
post-28373-0-55266600-1398212297_thumb.j
post-28373-0-07609900-1398212312_thumb.j
post-28373-0-37438500-1398212325_thumb.j
During boarding
post-28373-0-53688500-1398213064_thumb.j
During electrical trim-out
post-28373-0-41763000-1398213050_thumb.j
I'll show the bar and bath in the next few posts.
Thanks guys!
Wow. Really great work! Those lights are sweet. Are they 1 or 2 inch? That's a huge space. Very impressive you did it all yourself!!
Harold - I used a combination of 3" remodel lights and 6" cans. There are over 90 lights in this basement. The finished space is approximately 1700 square feet.
Here is the bath room from just about day one to almost day done.
The basement was already plumbed for a full bath but any layout that we could come up with, with the existing stub-outs made for an awkward layout. The toilet would have been in the middle of the room so I moved it.
post-28373-0-71196000-1398523779_thumb.j post-28373-0-54838300-1398523700_thumb.j
Kerdi shower under slate tile. Slate tile is a b!tch to work with. Not one piece was the same size. Every tile needed to be cut (my Dewalt tile saw eased the pain of this task).
post-28373-0-98132200-1398523045_thumb.j post-28373-0-92788600-1398523048_thumb.j
Shower floor
post-28373-0-64404000-1398523052_thumb.j post-28373-0-06115800-1398523056_thumb.j
Ditra Floor
post-28373-0-78366100-1398523703_thumb.j
Vanity
post-28373-0-65063700-1398523060_thumb.j post-28373-0-78190200-1398523911_thumb.j
Back-lit crown witch I have since change over to LEDS.
post-28373-0-36944000-1398523058_thumb.j
Wow! You did an excellent job.! You're really talented. I love the lighting job that you did. I find lighting to be the most difficult part of the project because it's so easy to either overdo it or underdo it but it looks like you hit the nail on the head.
Thanks DR and Matt,
Over the years I found that lighting is more than just for task. It can set the mood for the whole room and with open concept basements you can use the lighting to define the space.
Here are some bar pictures but don't get overly excited (DJ). It is more of a Kitchenette. It is only missing a range and an oven.
Here the Bar is ready for flooring.
post-28373-0-09625900-1398977886_thumb.j
I added some underlayment to raise the finished floor height so the transition from the carpeted section to the bar floor is smooth.
post-28373-0-33893800-1398977892_thumb.j
The flooring is an Allure click lock product. Super easy to install.
post-28373-0-25080200-1398977898_thumb.j
I ran the water supply under the toe kicks of the base cabinets and tied the waste into one of the main stacks. I used a threaded male adapter and coupled the run so it can be removed to meet code.
post-28373-0-81738400-1398978213_thumb.j
Cabinets going in... I practically had to rebuild the corner cabinet in order to meet plumbing code access for the plumbing stack cleanout.
post-28373-0-61731900-1398978331_thumb.j post-28373-0-41070100-1398978341_thumb.j
This is my favorite part. The booze shelves. I built this out of standard wine cabinets and upper cabinets. I needed the the larger upper cabinet to hide some HVAC. I wrapped these pieces in crown.
post-28373-0-06767300-1398978537_thumb.j
Then I created a back-lit booze wall. I made this out of poplar and plexiglass. I used my orbital sander (Dewalt) to sand the backside of the plexi to get a frosted look. I added some cleats to the cabinet and then I made a small face frame for the plexi glass. The framed plexi sits between the cleats and the shelves. The whole thing comes apart quite easily. Behind the plexi I installed some LED light strips that can be turned on an off with a remote. I tried to capture a couple colors for you guys.
post-28373-0-04800600-1398978534_thumb.j post-28373-0-92051700-1398978539_thumb.j
Big ass TV and done.
post-28373-0-39989200-1398978543_thumb.j post-28373-0-28449600-1398978529_thumb.j
Awesome work Brien. That basement is bigger than my condo lol. Great work and I really like your choice of materials for every project. I like the tile on the shower a lot and that lighting above the crown molding is amazing. Thumbs up!
Thanks guys. I appreciate the kind words.
This is not my home (but it kinda of was for almost a year). I do this work on the side.
This was the biggest basement that I tackled on my own. Usually it is just a room or two, or just a bar, or just a bathroom.
This basement also has a full gym which I overlooked when taking pictures.
I need to get to work on my own projects... I feel like like the shoemaker who has no shoes.
I have been using Ditra for some time now. In fact my Home Depot stocks it now.
Sometimes it can curl up on you but a well placed board and tool bag can go a long way.
It is a great product and I have never had longevity issues with it.
 The Home Depot near my home stocks the floor material but not the wall material. The wall material can be tricky at times. I'm looking in to the shower pan and drain have you ever y installed it before.
The Kerdi Shower System is a great product. It is a huge time saver and makes the shower completely water proof. It is practically fool proof too.
The pans are all pre-pitched and come in different sizes. If you can build the shower stall to fit one of their pans you will be in good shape. If you can't I would advise you to buy a bigger pan and scale it down to your size so the pitch stays consistent around the perimeter. The best part about the drain is that you don't need weep holes.
Once you go Shluter you wont go back.
I use this unmodified mortar on Ditra and Kerdi.
36b89b36-3ef9-4e7a-b2a1-a03a508a3efc_400
    stermscar
    stermscar
